05 SI electrical problems
Old Nov 5, 2015
Joel Branscome's Avatar
Joel Branscome is an unknown quantity at this point
I was putting in an aftermarket stereo and needed to cut and re-attach the stereo wire harness to be able to work with it. When I put everything back in, not only was the stereo not working but theres been a list of other problems.
Dome light wont doesn't turn on for door opening (will turn on if you click it)
Blinkers don't work (but will come on with emergency lights)
My key fob sopped working
Even if I didn't rewire everything for the stereo back properly, I don't understand how it affects all these other things. Any help is appreciated. Thank you!
Joel
Old Nov 5, 2015
Re: 05 SI electrical problems
Start looking for blown fuses, check BOTH fuse boxes.
IF you connected the the 'illumination' circuits to the new radio, you probably should pull it back out and disconnect them. Most aftermarket radios are not compatible with the dash lighting control method the cars have, and you can do damage to the car if you turn on the lights with it hooked up.
Old Nov 5, 2015
mikey1's Avatar
please tell me you disconnected your battery before doing this?
if not, its a big
because "other things" can be on the same circuit as the wires you are chopping, and when you chopped those wires you probably blew a fuse or two,
