8th Gen 2006 - 2011.
2010 Honda Civic LX-S Maintenance Minder System
Old Sep 17, 2015
WWJD's Avatar
WWJD is an unknown quantity at this point
I have a question about my 2010 Honda Civic LX-S Maintenance Minder System.
I know the oil life system counts how many miles I ran since the latest service.
However, do they count how much time passed since the latest service?
I meant if I don't run the car for 20 years right after a engine oil change, would the minder show 0% oil life or still 100% oil life?
Old Sep 17, 2015
Re: 2010 Honda Civic LX-S Maintenance Minder System
The system cannot tell time. You have to do that.
It does not operate as a simple mileage counter like older versions, this does not really track miles as much as it monitors conditions and habits. Depending on how you drive, it could display the wrench and reminders (want an oil change) in as little as 4000 miles or it might let you go 12,000+ miles.
The system operates on a design model, therefore it relies on someone using the correct fluids.
The system cannot actually physically monitor the oil or any other fluid or filters.
The system cannot tell if someone poured the correct spec oil in it or the crappiest discount oil.
HTH
Old Sep 23, 2015
h4ldol's Avatar
h4ldol is an unknown quantity at this point
So, should you get an oil change before the maintenance minder alert pops up if you're not using the car much and it's been a while since the last oil change?
Old Sep 23, 2015
CraigW's Avatar
The time interval was 1 year IIRC.
I used a 5000 mile set interval on 05 & 10 Civics.
But, may use the MM on the next car (9th gen) and just watch the percentage remaining, then schedule when getting close to 25-20%. Or, may use a 7500 set interval.
At 5000 miles using dino often it's at 30-40% remaining.... it will be hard to change my ways, but need to.
Old Sep 23, 2015
Honda does say one year max for an oil change.
I don't quite follow that rule on my 12.
alexkharden
Apr 23, 2015 07:13 PM
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
