bought parts and they dont fit engine swapped?
Old Sep 12, 2015
Dave Brabant's Avatar
Dave Brabant is an unknown quantity at this point
ok so i bought some parts off the web for a 96 non vtec 1.6l they got here and im ready to install everything and nothing fits... the guy i bought it from told me that the engine had been changed out for the same exact engine that was in it ... so my question is what engine do i have in here . I know i could check the side of the cyl head but the car is in the city in a buddies garage all dissassembled for install and parts dont fit.
ID:	88076   Click image for larger version
Old Sep 12, 2015
Re: bought parts and they dont fit engine swapped?
Yo Dawg! Is that thing got an air filter for the air filter?
I guess Canada EX doesn't have VTEC?
What's the engine code on the block?
What's the code on the head? Have your buddy look for it (search for this, I don't have the answers)
What parts did you get? What doesn't fit, and why?
Old Sep 12, 2015
NO DAWG... the air filter aint in it lmao just the gasket part is, its ghetto i know not my doing thats before the cai.
I got a couple parts timing belt and pulley, turbo manifold, some hoses and a fuel rail, some plug wires and some other stuff i havnt tried installing everything but when i saw the hoses wernt right and the timing pulley and belt wernt right allong with the manifold i stopped and left
Old Sep 12, 2015
Mad Dog Tannen's Avatar
Are you trying to turbocharge it? Why did you get a pulley, or did you mean tensioner? Why a fuel rail is there something wrong with the old one?
That looks like a D16 SOHC. Definitely not a VTEC engine.
Old Sep 12, 2015
got the stuff for cheap and i was just having fun the only marks he can see on the head are in the front are p2f-ha-2 and usa then theres the engine serial
D63220752L the old fuel rail was leaking abit , the pully was rusted, the turbo manifold is because yes a want to boost it abit. im trying to refurb this car abit as a project and get as much out of the non vtec 1.6 as i can the engine is still very healthy and runs like new still has good compression equal across al four. as stated in my last postes this is my first import build and the 50 different engines is confusing to me im used to playing with cars that either come with one or two engines and thats it
i assume none of those codes are telling me the engine where do i tell him to look for it
Old Sep 12, 2015
I am confused, you say you have a turbo manifold, but wheres the turbo? A rusty pulley shouldn't cause trouble, all of mine have been rusty and worked fine. Leaky fuel system is a priority though, that could be a fire hazard. And the timing belt is always a good idea if it hasn't been changed.
I would get it running smooth while it's stock first, then worry about modding. It sounds like nothing you're doing will add any power.
Old Sep 12, 2015
ok after looking up the code it seems i have a d16y4 IS that right? if so im going to do the y8 head swap i just found here
http://www.ozhonda.com/forum/showthr...wapped-with-y8
all these parts will be thrown into the trash because they are definatly not for a d16 like the guy told me
Old Sep 12, 2015
well thats what im doing the thing only has 129000 kms on it ... the only thing wrong with it is the fuel rail the rest was just for fun. the guy sold me the turbo with the manifold but the mani doesnt fit my y4 head so it wont fit the y8 head either.. besides i paid 120$ for everything except the belt and the fuel rail. I know a rusty pully is not going to cause problems but it came with the package deal and wasnt rusty so i wanted to change it
Old Sep 12, 2015
I see. I would just sand and paint the old pulley, but it's in a place that no one will see, so it would really just be for you. As someone who tinkers all of the time, I like to polish up and paint things that only I will notice, but I end up having to point them out if I want any recognition lol
Also those aluminum fuel rails are really easy to polish and they are very visible.
Personally I would work on attacking the massive amounts of rust in that car. Rust will cause you more headaches than anything else.
Old Sep 12, 2015
yeah the rust was planned. this all happened on a piff. i was in montreal and guy was selling all sorts of honda parts at a garage sale so i bought it, not the end of the world. At least now i know what engine i have in it XD. I love to tinker also, i keep doing stuff to it that only i know is done and dont really care if others see it or not. this thing hauls *** already compared to other non vtec d16s i have seen i mean if i give it WOT at a 10 km/h roll it burns tires all the way till second then burns about half way through second on winter tires. w/o power shifting it. done it twice so far to be sure. it got 16.1 on my only pass at the 1/4 mile so its definitely not low on power. (as far as i know) lmao if im completely wrong i apologize, im trying to learn the import stuff and its way different then domestic. seeing as my last build was a f150...
Old Sep 12, 2015
foreign and domestic engines are all internal combustion four stroke gasoline piston engines, same symptoms, same problems. The parts are not quite as interchangeable as the GM's that I have owned is the only major difference, that and the aluminum engines (older cars). The D series engine is bulletproof and will last a long time if you take care of it.
That is why I did not buy a VTEC or DOHC engine. Simplicity is reliability.
Old Sep 12, 2015
Probably not, unless you are Turkish, Aussie or Kiwi.
D16Y4
Found in:
  • 1998–2000 Civic 1.6 iES (Turkey)
  • 1996–2000 Civic CXi, GL, GLi (New Zealand, Australia)
What is the code stamped on your engine block?
Examples:
Old Sep 12, 2015
D16Y4
Found in:
Examples:
heads code corosponds withthat of a d16y4 but the block says d16y7 ive got a z6 head lined up for a mini me swap 70 $ so im gonna jump on it. in further news waters gettin in my passenger side its been raining all day and the m'fer is soaked
mistermenphis22
Apr 3, 2016 08:06 AM
cloudguy
Apr 28, 2015 05:02 AM
bsmiley
Apr 27, 2015 01:27 PM
shawe90
Apr 14, 2015 07:10 PM
streetglower123
Apr 12, 2015 10:56 AM
