Noise After Replacing Springs
Old Aug 28, 2015
cukaracha's Avatar
cukaracha will become famous soon enough
Hi all,
I bought my 2000 Si used and for as I've owned it, it's had an audible rubbing/squeaking/soft-groaning noise whenever I go over bumps or uneven roads coming from all four wheelwells. The previous owner had replaced the struts and springs with Koni STR.T and Tein S-Tech.
During the pre-purchase inspection, the mechanics told me that the noise could be caused by worn out strut mounts. The previous owner mentioned that he didn't replace the strut mounts when he did the suspension work, so I figured that could be the cause of the noise.
I replaced all four springs yesterday to Eibach Pro springs and also replaced all the rubber bushings and mounts but not the bump stop. The noise is still there and has not subsided at all.
I noticed that the front sway bar links need to be replaced, but the rear ones were fine.
Any idea what might be the issue?
Old Aug 29, 2015
GolNat's Avatar
Prelude Owner
Re: Noise After Replacing Springs
You can try disconnecting the front end links and seeing if the noise goes away.
cruisers10
May 12, 2015 10:46 PM
oneheadlight
Apr 29, 2015 11:30 PM
thesushiboy
Apr 12, 2015 02:54 AM
JeffSpeed21
Dec 5, 2001 04:58 PM
klam
Nov 14, 2001 03:45 PM
