bad knocking sound when clutch pedal in
Old Aug 28, 2015
violentpanda's Avatar
violentpanda is an unknown quantity at this point
So i was driving down the street.. stopped to get smokes and i hop back in and my car has a horrible knocking noise only when i put pressure on the clutch pedal.... ive torn it all down... inspected my clutch components and cannot see any obvious damage or problems.... when i put it all back together with a new throwout bearing in it and fresh fluid... still knockin like the police.... please for the love of god help me....:/
Old Aug 28, 2015
Re: bad knocking sound when clutch pedal in
Hide yo stash!
See if the knock is coming from the engine instead of the trans
Measure crankshaft end play (checking for thrust bearing wear)
Old Aug 28, 2015
Ive looked at the rear end of the engine and felt for any looseness or anything obvious but everything seems tight.... lack of a dial indicator leaves me without exact measurements..... it only happens when the clutch has pressure on it.... never when driving,or in neutral or anytime the clutch is engaged... only once the pressure plate has pressure applied to it
Old Aug 28, 2015
Do you have to push the clutch pedal all the way to the floor to make the noise, or will it make noise if you just rest your foot on the pedal without pushing it down enough to disengage the clutch?
Old Aug 28, 2015
Even just resting my foot on the pedal gives a light knock.... the more pressure i apply the louder it gets...
Old Aug 28, 2015
That should rule out a pilot bearing noise then.
Seems like you're probably down to something in the throwout mechanism, pressure plate/fingers, or crank thrust. Or something else oddball that wouldn't be typical.
Stethoscope it, figure out if noise comes from trans area or engine area?
Old Aug 28, 2015
Ok... ill have to get a helper... ill give it a shot n see what i can come up with..... hopefully not anything block related..... really dont feel like pullin the engine out.... thanx ezone
Old Aug 28, 2015
I sure wouldn't expect it, but right now nothing has been measured and ruled out.
Old Sep 7, 2015
Finally got a whole new clutch set with flywheel.... narrowed it down to the clutch case when i got a real good listen in... so today its out with the old and in with the new! Wish me luck! I sure do hope this fixes my ailments
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
Supramk3
May 8, 2015 11:16 AM
bsmiley
Apr 27, 2015 01:27 PM
02EXCoupeGuy
Dec 19, 2001 09:47 PM
