Turn signal help
Old Aug 26, 2015
jonwalden68's Avatar
jonwalden68 is an unknown quantity at this point
Turn signal help
I just got this 97 Honda Civic ex first off when I bought it the right side turn signals flashed fast but still blinks so I changed every bulb twice on right side still blinks fast except for when the running lights or head lights are on it slows to below normal. I cleaned the grounds and put grounds straight to frame and battery and didn't change nothing and I doubled checked all bulbs are correct size the flasher is new I put 2 different ones in and the fuse is good any help be great it's driving me crazy
Old Aug 26, 2015
Re: Turn signal help
Anyone?
Old Aug 26, 2015
You're probably missing something that should be easy to SEE in the lights if you really look.
Turn on 4 way flashers, stare at the front and stare at the back of the car.
Compare left to right. What's lighting up just a little different?
Leave the 4 ways on and turn on the rest of the lights.
Now look at the fronts and rears. Where's the difference?
Any side markers supposed to flash? (IDK, just guessing)
Old Aug 26, 2015
I tried that and can't tell a difference unless something from the driver side could cause the passenger side to flash fast
Old Aug 27, 2015
Update I put a new flasher in it fixed thr slow flashing with head lights on but still hyper flashes
Old Aug 27, 2015
If it flashes fast on one side then that usually means the current draw is not high enough, usually meaning a bulb is out or the wattage of a bulb is not high enough.
To elaborate on post #3: Just lighting up isn't good enough, the bulbs must be the correct brightness at the correct times. If you have the front bulb wired wrong or installed wrong (or wrong bulb altogether), the dim filament could blink with the turn signals and the bright one would come on with the park lights.
If the other side works correctly, try swapping the front park/turn bulbs and sockets.
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
my2k1vic
Jan 8, 2002 08:31 PM
