8th Gen 2006 - 2011.
Engine oil change before roadtrip?
Old Jul 1, 2015
civic1991's Avatar
civic1991 is an unknown quantity at this point
Question Engine oil change before roadtrip?
Hi everyone. I will be taking a road trip to Texas this weekend, and it will be roughly 2000 miles. My 2012 Civic (~85000 miles) is due for oil change June 22, but I still have 50% oil life remaining according to the system maintenance display in the car. Should I change my oil before this long trip or should I let it eat some miles and wait until 15% oil left? Thanks!!
Old Jul 1, 2015
jordan1794's Avatar
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
Re: Engine oil change before roadtrip?
You'll be fine, it's mostly highway.
The minder tracks the type of driving that's being done. The actual range it tells you between changes could be anywhere from 3k miles, to 10k miles.
(Or more, or less...not really sure how short or far it will stretch)
In fact, I had around 2k miles on my oil in my 2006 when I drove across the country, when I got back around 5k miles later it still wasn't at 15% (I went ahead and changed it though)
Old Jul 1, 2015
jordan1794's Avatar
Actually, looking back at my posts:
https://www.civicforums.com/forums/1...ew-months.html
Apparently I went almost 7k miles during the trip
So my total mileage on the oil was very close to 10k miles, still was not at 15% yet though!
Old Jul 1, 2015
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
I would change it. I don't pay any attention to my oil monitor if I did
I would be buying a engine wich Honda would love to sell You.
7,000 u.s.a miles is the max on synthetic oil to go in my opinion.
Old Jul 1, 2015
The minder system oil life calculation is reportedly conservative, so if I know for certain it has the correct spec oil in it, I'd run it. Make sure all the vital fluids are full and hit the road.
I'd also check the oil level at fuel stops during the trip-- out of habit.
(If you get JizzyLube or Wallymart oil changes where you have no idea what oil is really in there, I wouldn't do it.)
Old Jul 2, 2015
civic1991's Avatar
Currently my car is running on 0W20 syn blend gotten from the Honda dealership, and just did a full 75k service 3 months ago.
Old Jul 9, 2015
brags's Avatar
Civic1991 why ? is the Honda You go to using
a synthetic blend 0w20 oil..? I can understand the 0w20 because
of tight tolerances & fuel econo and emmisions. but in a synthetic blend.?
that's like getting just half if not less than the protection if you were to use a synthetic oil. Your much better off running a good synthetic oil and synthetic oil filter
Old Jul 9, 2015
There is no 'conventional' 0w20.
All 0w20 is considered synthetic blend, or better.
Honda approved dealer bulk 0w20 oil is synthetic blend.
It's great oil, most engines can live a long healthy life on it following the MM suggested intervals without lubrication related failures. (Owner needs to check oil level once in a while though, same as with any other.)
Full synthetic (usually bottled) should also be available at dealers......of course it's probably sold for a higher price.
We keep Honda labeled full syn and Mobil-1 in stock, but almost nobody buys the Honda labeled stuff.
I personally don't see any additional benefit in paying extra for full syn these days. JMHO.
BUT I buy Mobil-1 V-Twin 20w50 by the case for my Harley LOL
Old Jul 10, 2015
mikey1's Avatar
in my opinion most people tend to over think oil changes,
your chances of an oil related failure in these engines is next to zero, even if you go 1-2k past suggested intervals, unless your letting your oil level get severely low
Old Jul 11, 2015
brags's Avatar
ezone some Honda dealers will push that semi-synthetic oil to keep costs
down for costumers that follow Hondas oil monitoring system as far as %
goes to change it. what bothers me is Honda uses a in car programed oil %
montoring oil system based on "Normal duty driving" what
about outside ambient extreme humid or cold temps or combined under hood temps.? it cant measure hours in traffic like farm equipment can? so what good is it.? oil monitoring systems should be monitoring under sever duty NOT a one size fits all normal duty. Your much better off with a full synthetic
oil instead of a "semi-synthetic that will give You half the protection if
not less"
Old Jul 11, 2015
jordan1794's Avatar
Er, actually the minder DOES track the kind of driving being done.
Depending on the type of driving it can signal for an oil change anywhere from 3k, to maybe close to 10k!
If Honda wasn't 100% sure about the system I'm sure they wouldn't introduce it, imagine the lawsuits if cars were dropping engines due to following the exact instructions.
Old Jul 11, 2015
What Jordan said is correct for the maintenance minder system.
The minder system does take into account those factors (except humidity)
I'm sure a google search on the subject (in general) could yield some reading material.
The Honda approved semi-synthetic oil we use is absolutely acceptable, it meets ALL of Hondas oil specifications, and a user should have no problems following the minder system calculated intervals (as long as correct oil is used).
The older cars' oil change reminder light was attached to a simple mileage counter, your concerns would be more valid on those cars.
Xuhme
21
Aug 7, 2023 03:40 PM
MyCivic
Electrical
Oct 28, 2021 11:06 PM
BootyDo
May 7, 2015 04:46 PM
CivicVoz
Apr 16, 2015 08:07 PM
Grazzhopper
Nov 11, 2001 08:06 AM
