Ignition Lock/Sensors Broken??
Old Jun 20, 2015
bluedoggy1's Avatar
bluedoggy1 is an unknown quantity at this point
car:
03 civic ex coupe
changes to car leading up to problem:
-ignition lock seized between 0 and I positions
-disassembled it to try and fix on the spot
-had locksmith come and fix it and made new same cut key with previous key's chip
-car worked fine until I closed door with key (enabled alarm) and could not disable alarm until I disconnected immobilizer connector from ignition lock
*alarm/keyless entry worked with that connector unplugged but had to reconnect to start car*
-ended up just ripping out aftermarket alarm but keyless/stock alarm doesnt work still (didnt try without immobilizer disconnected this time) however the remotes do get programmed by doing the on-lock-off-on-lock-etc method
-however something I noticed is that when I open door (without key in ignition) I get the beeping noise (isn't that just for when key is in ignition?), could this be problem? how can I fix this?
Thanks for any information in advance.
danace99
Oct 17, 2015 02:51 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Bruce2
Sep 27, 2015 08:45 PM
Donahue
Sep 9, 2015 05:55 PM
