a/c not working
Old Jun 16, 2015
granny828's Avatar
granny828 is an unknown quantity at this point
a/c not working
I have a 2003 honda civic. My a/c isn't working. I took it to my mechanic and he doesn't have what is needed to test exactly what problem is. He said the a/c it's self is working just not being told to turn on. He said it could be in wiring or sensor or something else he just can't test it to find out. I need help please. I'm 63 and on disability with limited funds but in need of my a/c. PLEASE ANY HELP WOULD BE APPRECIATED !!!!!!
Old Jun 16, 2015
Re: a/c not working
Does the scanner data indicate there is an AC request seen by the PCM?
Is the thermal protector open circuit?
At the pressure switch, is the blue wire being grounded by the HVAC panel?
Old Jun 22, 2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
Re: a/c not working
anyway your mechanic will ask questions on this forum so he can better help you?
someone here might help you, what city are you in?
Old Jun 26, 2015
mrohitredd's Avatar
mrohitredd is an unknown quantity at this point
Re: a/c not working
I did the below...
1. Removed Wheel & Splash Guard to access the clutch.
2. REMOVE Clutch Plate >>> Got a universal AC clutch tool - which was useless to me, as it only wasted time in trying to hold the clutch plate. At last, i used an impact driver & the nut came off very easily - Try the same & save yourself a lot of time.
3. Cleaned thoroughly inside & out (be careful with the tiny washers inside the clutch plate).
4. Put everything back. Been driving it for 2 days now. AC doesn't stop as it used to before. Will check for few more days & let you all know if it dies again (i will change the clutch, if so).
No harm in trying this... Its free of cost rather spending $400-$600 to replace the clutch. Could be temporary too, but worth the savings !
Thanks.
Old Jun 26, 2015
alex_nyc's Avatar
Re: a/c not working
Originally Posted by mrohitredd
I did the below...
Thanks.
did you fix grannys car?
mikemc422
Aug 9, 2018 05:41 PM
trellex
May 24, 2015 04:39 PM
ORskier
May 3, 2015 12:54 PM
paulnguyen
Apr 20, 2015 01:33 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
