What would you do with this oil leak?
Old Jun 5, 2015
thesushiboy's Avatar
200,000 and counting
thesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the rough
Pretty sure that's a crankshaft seal leak. I know I should have replaced it when I did the timing belt a few months back...
It leaks about a teaspoon a day, but I really, really don't want to go back into the belly of the beast and pull the timing belt/crank bolt again.
Thoughts?
Last edited by xRiCeBoYx; Jun 8, 2015 at 01:48 AM. Reason: made the image viewable in the thread
Old Jun 6, 2015
Blazz's Avatar
Blazz is an unknown quantity at this point
Re: What would you do with this oil leak?
Is it a teaspoon after you tried stop leak? If not try stop leak. If so The car is wounded it needs the Operation even stop leak is just a band-aid but can slow the process if your in a bad spot.
Old Jun 6, 2015
GolNat's Avatar
Prelude Owner
Put something under the car to catch the oil. Check oil level regularly, add when needed.
Replace seal when you can.
Old Jun 6, 2015
mikey1's Avatar
could also be your cam seal, and the oil is running down,
an oil leak in the timing area is the worst place to have one,
eventually your timing belt will be covered with oil and it will spray it around everywhere under the cover,
an oil soaked timing belt can snap prematurely
Old Jun 15, 2015
tkcne's Avatar
tkcne is an unknown quantity at this point
Mine looked like that and when I got it apart there weren't any obvious leaks inside the timing compartment. I replaced all the seals anyway just because I was there. Even after I finished I still had a leak running on to the bottom of the pan. It was the vtec solenoid o-ring. I would suggest taking a good look at that first. It could also possibly be your oil pump o-ring. Check that if you get into the timing compartment and still don't see anything.
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
Kyrian
Jun 26, 2015 11:48 AM
671civicLX
Jun 13, 2015 05:56 PM
davidpaustin
May 20, 2015 12:59 PM
