transmission issue
Old May 24, 2015
jackshepardjr's Avatar
jackshepardjr is an unknown quantity at this point
transmission issue
I have an 03 civic ex manual transmission. Just had new clutch put in. Car ran fine for a month. Now having issues with first, third and fifth gear. First engage half the time, third gear I need to hold clutch, put in gear, take out, then put back in third to engage, and fifth engages once every 10 tries. Has anyone had this issue before?
Old May 24, 2015
Re: transmission issue
I suppose the shifter feels different now for those 3 gears?
Sounds like it may be a cable issue, most likely at the trans end.
Maybe a retainer clip came out, now the cable housing is moving in the bracket?
Need another person to work the shifter while you search in the engine compartment.
Return to your clutch installer for a recheck since they just had it all apart.
Old May 24, 2015
Finally, someone with some info I can use. Thank you. I almost bought a transmission to swap. I'll try this first.
Old May 24, 2015
civic__duty's Avatar
civic__duty is an unknown quantity at this point
This may be off base, but make sure they torqued the clutch on with the right amount of pressure and evenly on all bolts. I wasn't able to go into any gears on my integra with a fairly new clutch because of improper installation.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Midnapore
May 18, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
Jessica Leung
May 5, 2015 05:12 PM
markp94
Apr 30, 2015 09:19 PM
