How to get top timing belt cover off to inspect the belt
Old May 22, 2015
EdGasket's Avatar
EdGasket is an unknown quantity at this point
It should be so easy because it is important to check the timing belt from time to time. I just bought a year 2000, 1.4s and need to see what state the timing belt is in. I undid the two bolts on the top timing belt cover, then realised it is also locked in place by the rocker cover (what a pain). Having removed that, it still wouldn't come off. Seems like there's a piece of plastic attached to the top cover at the bottom rhs that stops the right hand side pulling out by more than about 1 cm and the left side will only pull out a little due the the plastic bit that surrounds the dipstick fouling against the power-steering bracket.
What is the need for that piece of plastic on the rhs; it is bolted up there anyway? Should I just cut it off and see if I can wiggle the cover out ? (its right up against a power steering hose but should come out if I could only free the rhs). Much easier on my Hyundai, 4 easy bolts and cover is off!
Old May 22, 2015
Re: How to get top timing belt cover off to inspect the belt
We don't have 1.4 engine here (North America)... You must be in the UK?
I can't picture what you describe as I have not seen a 1.4.
Got pictures you can post?
Some upper covers have 2 bolts, some use 3.
Some wiggling can be involved to get it loose too, like a puzzle.
Old May 23, 2015
EdGasket's Avatar
Thanks for the reply. Yes I am in the UK.
I found out from the garage that had been servicing it that the timing belt was last changed 8 years ago so it needs doing anyway.
Old May 24, 2015
honda200192's Avatar
honda200192 is an unknown quantity at this point
Most of the time you go off mileage intervals. Here in the U.S most honda manuals say every 60,000 miles for a timing belt replacement. I dont know about in the UK.
Old May 25, 2015
EdGasket's Avatar
For the SOHC it's 60,000 miles or 5 years whichever comes sooner. It makes sense because the belt will deteriorate with age too. Gates say the shelf-life of their belts is 8 years (after which the belt should be thrown away although annoyingly they don't date-stamp the packaging and the belt is coded so only they can work out when it was made). Dayco say shelf-life is 5 years and they do mark the belts with a readable code (first two digits is year and second two the week in the year) but again don't mark the packaging.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Supramk3
May 11, 2015 07:55 PM
Supramk3
May 8, 2015 11:16 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
