Suspension noise - a "knock" when giving gas or letting off - what is it?
Old Apr 7, 2015
Ian SFBA's Avatar
Ian SFBA is an unknown quantity at this point
This is a new-to-me 2003 Civic DX coupe with manual. It has 95K mi. on it.
When first taking off from a stop, or when disengaging from 1st, I hear and feel a slight "knock". It sounds and feels like a suspension issue (no mods on this car).
This happens in slow-speed situations, say when just taking off from a stop, or when shifting from 1st to neutral in a stop and go situation. It happens when first using the gas, even in a mild acceleration, or when taking my foot of the gas.
I figure it's happening at other times, but I'm not hearing or feeling it as much, if at all (1st to 2nd, etc.).
It sounds like something in the suspension - a bushing maybe. Feels more like something in the rear, rather than front, but I really haven't been able to zero in on a location.
Does this sound familiar to any of you?
This is my first post (my first Civic). Thanks!
Ian
SF Bay Area
Old Apr 8, 2015
GolNat's Avatar
Prelude Owner
Re: Suspension noise - a "knock" when giving gas or letting off - what is it?
I would start removing wheels and checking for worn components. I would check your motor and trans mounts also, those could be worn.
Does it knock once then stop? Or is it a rotational sounding knock that is dependent on speed?
Old Apr 8, 2015
mikey1's Avatar
my guess is lower ball joint,
whatever it is, get it fixed asap
Old Apr 8, 2015
Ian SFBA's Avatar
It only knocks the once on change of direction forward or backward, that is, on slight acceleration or deceleration. No rotational noises.
I did go around the car giving each wheel a good rocking, but didn't notice anything unusual, though, it would be best to do this while on a lift, I'm sure.
I've never got into suspension issues, so your suggestion to check the lower ball-joint, mikey1, is helpful, too. I have first to educate myself on just what's under there and what it all does.
I was hoping it would be a simple matter of tightening something.
Only 95K on this, and no hard miles, I don't think. But the car has has a few knocks - a bit more than the shopping cart kind.
I'll start Googling components to better understand the suspension. Then I'll have to crawl under there and give it all a thorough inspection. Thanks guys!
Ian
SF Bay Area
Allecr3
May 22, 2015 01:24 PM
Ninetyatecivic
May 9, 2015 07:48 PM
tylerginevan
Apr 27, 2015 12:29 PM
Guy01
Nov 6, 2001 03:25 PM
silvercallx
Aug 19, 2001 12:36 AM
