00 civic not pickin proper speed
Old Mar 13, 2015
cvcowner's Avatar
cvcowner is an unknown quantity at this point
I have a 00 civic 5sp I'm having an unusual problem at least that's what I call it I can press the gas pedal to the floor the engine does not accelerate or nothing it takes what seems forever to pick up speed anyone out there can help me ? any suggestions will be appreciated it thanks guys
Old Mar 13, 2015
Re: 00 civic not pickin proper speed
So it runs bad?
Low power?
Gas mileage went to hell?
High mileage? Jumped time?
Check engine light on?
Got codes?
Old Mar 13, 2015
cvcowner's Avatar
it does have high mileage ezone, runs just fine that's the only big problem with it ig u can say but I've serched around n I'm not the only one with this problem even new models say it does it but nobody has no real answer to what it could be some say it's the computer that's not catching up to the speed when u give it has and no no codes are shown check engine light comes n goes never stays on so there's no good way to catch a code if there was any
Old Mar 13, 2015
Vague description from a non-technical point of view:
I can only picture what this might feel like to someone driving the car as it happens.
Could be many things, from a serious running problem to clutch slippage.
You don't have much solid useful info to go on as far as searching goes.
I don't have any way to feel what is occurring myself, nor can anyone else. There could be a hundred different things that could go wrong with it that could generate similar complaint descriptions from any number of people.
As a tech I tend to notice to all sorts of things the average driver would never notice.
Example:
Driver says "car won't start", and that's it. It's over for them. They are already cussing and calling the tow truck.
Tech jumps in and immediately begins analyzing 150 different things within the time it takes to turn the key, has assessed much useful information in that 10 second time span, and has mentally constructed a plan of action consisting of several next steps to figure out WHY it doesn't start.
The computer has a memory and retains code information (in most cases) as long as is does not lose battery power.
Plug in and see what the computer can tell you. Post results here.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
dragonsblood
Apr 27, 2015 12:28 PM
GH04si
Apr 15, 2015 08:13 PM
dooner24
Apr 14, 2015 07:51 PM
