Loses power @ 3000RPM
Old Mar 1, 2015
moparformance's Avatar
moparformance is an unknown quantity at this point
I am having the same exact problem in my 2001 lx with D17A1 non- vtec but it loses acceleration at the same time! I'm baffled because it will idle all day long not a single problem. But as soon as i start to try and drive it, BAM 3rd gear at 3000-3500 rpms it starts to grrrrr and break up. Then loose power or acceleration! PLEASE HELP
Old Mar 1, 2015
Re: Loses power @ 3000RPM
Got codes?
Got oil?
Got exhaust restriction?
Got intake restriction?
Old Mar 1, 2015
No restrictions, got oil, and the only code is for the O2 sensor because I'm running a 4 to 1 header with no cat.
Old Mar 1, 2015
You've checked codes since this new problem popped up? Today?
Old Mar 1, 2015
The only other codes that popped up since this first began was misfire codes for each cylinder and a code for multi misfires but that was corrected when i changed the coilpacks
Old Mar 1, 2015
When it loses power (floor it and let it go as far as it can) does it backfire and pop in the engine compartment?
Old Mar 1, 2015
If I floor it, it acts like its just lossing power and popping but no backfire. I'm at a loss!
Old Mar 1, 2015
You have checked codes today?
How long has this car been acting this way?
No backfire in the exhaust, but pops through the intake?
Popping through the intake might indicate it's lean, starving for fuel.
Just a guess here, so if I have a car in the shop and I suspect that's happening:
I'd use a scanner to watch the front O2 sensor values and see if it shows as lean during the event, and check fuel pressure--connect gauge, tape it to the windshield so I can read it while driving, and drive it so it acts up and see if the pressure drops a lot while it's acting up.
Got a ton of miles on this car?
Old Mar 1, 2015
It has been sitting and being worked on for 3 months now. I checked the codes today and it was the usual bank 1 o2 sensor. Believe it or not my car has less than 80000 miles.
Old Mar 1, 2015
What code is that?
So you are not driving it? You lost me here.
Old Mar 1, 2015
I'll pull the code again to post it and i try to drive it around my neighborhood every couple of days.
Old Mar 1, 2015
Someone suggested it may be in limp mode?
Old Mar 1, 2015
That's why I was asking about the codes, trying to figure out if there are codes that would relate to a limp mode, like for VTEC or Cam/Crank sensors..
What is your O2 sensor code number now?
Old Mar 2, 2015
The O2 code is P0135. But while trying to do the relearn procedure where you hold it at 3000 rpms for 5 minutes it threw P300,P301,P302,P303,P304
Old Mar 2, 2015
Ok that's a heater circuit code.
Shouldn't run in failsafe for that.
For the heater circuit inside the sensor ....Resistance spec says 3.0-3.6 ohms.
At 3000 RPM? Does it bog out at that speed?
Is it setting misfire codes because of how it runs?
The only reason they have you hold the RPM up like that is to get the engine up to operating temperature somewhat quickly.
It's not necessary to hold it there like that.... you can simply drive it around to get it warmed up.
What kind of work are you doing to it?
Does this car have a cat on it?
Does it sit outside in the cold?
Old Mar 2, 2015
I have a short air intake, a 4 to 1 open header and a flow thru muffler. I run only Royal purple oil and medium grade gas.
What I believe started the whole situation was shortly after i had replaced the valve cover gasket. I orginally didnt seat the spark plug tube grommets in the valve cover properly. So some oil got into the spark plug tubes. So i changed the spark plugs and coil packs first with no luck. Then I tried the map sensor with no luck. Next was the iac also no luck.Then was the evap purge valve, still nothing.Both O2 sensors were also changed. I even changed the IAT sensor. I think that about covers it! The only thing left is the throttle body and the ecu/pcm. So I just dont know what else to do.
Old Mar 3, 2015
Checked cam timing?
Does this car have a cat on the exhaust?
Old Mar 4, 2015
No it is pretty much an open exhaust but it does have a resonater. I have not checked the timing.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
0396
May 4, 2016 07:14 AM
Dave1984
Jul 22, 2015 06:10 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
ZILLA
Jul 13, 2015 04:52 AM
