1999 civic D16y8 p0505 ideas
I have a stock 99 EX and recently it's developed the p0505 issue. I've seen this on many threads but none of them seem to come to a conclusion, so I'm looking for help!
At around approx 1500 rpm engine pulses erratically with throttle pressure, and releasing and reapplying pressure to the throttle while driving produces a violent jerk. The car will buck if you are in that 1500-1700 rpm range. This only happens when the car is at operating temperature.
1. Sitting at a light, the idle will suddenly rise about 400
2. Cel will immediatly come
3. What I described above will happen
If I clear the cel while driving the issue suddenly goes away but will come back a day or 2 later. So far I've checked for vacuum leaks and cleaned the iacv, but that only worked for a few days. Please help!!! I have a scanner that shows some live data if that helps!
Ps: car also has p0420 which is a cat code and is probably unrelated FYI
Re: 1999 civic D16y8 p0505 ideas
Vacuum leaks? Cruise vac hose off?
IAC sticking?
Is it a rotary type IAC valve (auto trans car)?
IAC sticking?
I did my best to look for vacuum leaks but didn't see any noticeable ones..I checked the cruise vacuum hose that attaches to the nipple and it was good too. The iacv looks nice and clean now, are there any tests you can do on it? The car is a manual 5 speed
Pull the intake snorkel off the throttle body while it is surging.
You should see ....maybe 2 ports in there. Plug off the open ports inside the throttle body with your fingers.
Which port makes the most difference? Any difference?
What does the engine do when you plug it off? Does it die, almost die, or idle at the right speed?
What does the idle speed do when you unplug the wires from the IAC valve?
So your IAC should be a plunger type bolted to the back of the intake manifold? (#9)
Tap on it with a screwdriver handle or tiny hammer (not hard enough to dent the aluminum!) and see if that changes anything.
usajags84
15
Aug 19, 2015 03:12 AM
Braun
Apr 23, 2015 09:03 PM
aultman1990
Apr 19, 2015 07:14 AM
dooner24
Apr 14, 2015 07:51 PM
