Rough, low idle
Old Jan 30, 2015
jayman9782's Avatar
jayman9782 is an unknown quantity at this point
Rough, low idle
I have a 1998 Civic LX. About 2 months ago I noticed the idle speed was pretty low after the engine was warm. It wasn't too bad at first. A few weeks ago I got code P0420 (CAT). I noticed the exhaust manifold was split nearly in two when I took the heat shield off so I replaced the manifold/CAT. That took care of the P0420 code, but not the idling problem. That got worse - to the point that anytime I clutched the car at low RPM's, it would stall. I then took the IAC valve off and cleaned it out. I noticed the inlet and outlet for the coolant were completely gunked up, so I cleaned them out. The valve itself seemed to move freely, but just in case I cleaned it all out with electronic parts cleaner. I drove it a bit and it seemed better, but still idled around 500 rpm's. I put some fuel treatment and dry gas in (I live in northern NY with temps very often in the negatives) just to see if there might be a problem with water freezing or something else in my fuel. I've driven about 60 miles since then and it still idles around 500 rpm's once the car is warmed up.
Anyway, any ideas/suggestions on what to try next. Do you think the IAC valve is toast? Fuel filter maybe?
Old Jan 30, 2015
Re: Rough, low idle
If there is a screen covering one of the holes in the IAC valve, scrape all the carbon buildup out of the screen mesh. This usually fixes the low idle problem on most for me.
Old Jan 31, 2015
jayman9782's Avatar
Re: Rough, low idle
Thanks. I couldn't get the adapter off before because the screws were really stuck. I'll have to try harder.
Old Jan 31, 2015
Re: Rough, low idle
Hang on.... You have a downdraft throttle body with an IAC screwed to the front of if? It might just be stuck, the rotary valve inside can get caked with goo.
In my previous reply I thought you had the type of IAC that bolts to the rear of the intake manifold, it has a screen in one of the ports. My mistake, sorry.
Old Feb 5, 2015
jayman9782's Avatar
Re: Rough, low idle
No worries. I just finished tearing it apart again. I cleaned it, and the throttle bottle out to the point that my g/f would eat off it. The valve seemed to move freely.
When I first start the car cold it idles very evenly at 1500 rpm's. Once the car is at operating temps while I'm driving it, it runs perfectly fine. When I stop at a stop sign it idles at or a bit lower than the 500 rpm mark for about 5 seconds and then evens out around 700. For those 5 seconds it acts like it wants to stall.
There is no CEL to indicate any sensors are bad.
Any other thoughts?
Old Feb 5, 2015
Re: Rough, low idle
After you cleaned it all, did you do an idle relearn?
Old Feb 5, 2015
jayman9782's Avatar
Re: Rough, low idle
I didn't. What is the procedure for my car? Thanks!
Old Feb 5, 2015
Re: Rough, low idle
Basically, this:
Originally Posted by gearbox
1. drive car til its warmed up.
2. turn car off, disconnect battery or pull FI ECU fuse out.
3. put fuse back, start car, close hood
4. make sure all accessories are off, do not press any gas or brake
5. just let the car idle for 10 mins by itself
6. turn car off, then back on, and go for a drive like you normally do. it will take usually one tank of gas to completely relearn the fuel trims.
this is basically how the honda service manual says to do it. and its only done to correct idle problems caused by tinkering and taking apart intake throttle body and related sensors. this really is called "idle learn" procedure, which is essentially what you are doing by relearning the idle speed of 700 rpms.
Old Feb 5, 2015
jayman9782's Avatar
Re: Rough, low idle
Basically, this:
Great, thanks! Its about 15 below zero/f here right now, so I'll give it a try tomorrow/this weekend.
Old Feb 8, 2015
jayman9782's Avatar
Re: Rough, low idle
I followed the process that you gave me. I also unplugged the 7.5 amp backup fuse next to the FI e/m fuse because I read that it is a backup ECU fuse. I drove the car 200 miles yesterday. The car is not quite idling where I feel it did before (about 1K), but it is now idling at a steady 7-800. This seems to have fixed it, but I'll post if anything changes.
Thanks alot for your help, ezone.
Old Feb 8, 2015
Re: Rough, low idle
1k is too high for when the engine is at operating temperature.
750ish sounds good.
The spec may be listed on the emissions label in the engine compartment or on the hood.
freyes23
Jun 21, 2015 10:37 AM
The Big Dutch
Jun 9, 2015 07:49 PM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
