how do you properly reset the ecu
Old Jun 22, 2009
lowlife9's Avatar
ive looked at multiple sites and have gotten multiple answers like disconnect the battery and pump the brakes ten times then connect the battery and let idle till warm, connect battery and go to 3000rpms for 2 minutes ,drive on roads and highway for half an hour while turning on all electrical accessories . plus many more so what's the proper way ????
Old Jun 22, 2009
Re: how do you properly reset the ecu
1. drive car til its warmed up.
2. turn car off, disconnect battery or pull FI ECU fuse out.
3. put fuse back, start car, close hood
4. make sure all accessories are off, do not press any gas or brake
5. just let the car idle for 10 mins by itself
6. turn car off, then back on, and go for a drive like you normally do. it will take usually one tank of gas to completely relearn the fuel trims.
this is basically how the honda service manual says to do it. and its only done to correct idle problems caused by tinkering and taking apart intake throttle body and related sensors. this really is called "idle learn" procedure, which is essentially what you are doing by relearning the idle speed of 700 rpms.
heres the fuse
Old Jun 22, 2009
heres the fuse
Old Jun 22, 2009
lowlife9's Avatar
what kind of gas should i use does it matter much ???
Old Jun 22, 2009
lightningslp77's Avatar
lightningslp77 is an unknown quantity at this point
whatever you normally use. our cars were meant for 87 octane anyways. you don't want to "idle learn" your car for 91 when you pump 87 in it everyday.
Old Jun 22, 2009
the motor runs best on 87 octane and makes more power while operating cleaner. using the wrong octane will cause the ecu to adjust the timing and you will get worse power and mileage while clogging the engine with carbon buildup since 89-93 is too hard for our low compression motor to burn properly.
Old Jun 22, 2009
lowlife9's Avatar
once again gearbox comes threw with the info . very much appreciated .
Old Mar 18, 2013
truefriend's Avatar
truefriend is an unknown quantity at this point
why ia their so many ways
Old Mar 18, 2013
truefriend's Avatar
WOW like crazy man
Old Mar 18, 2013
4 year thread revival...
Old Nov 21, 2015
pcollen's Avatar
pcollen is an unknown quantity at this point
heres the fuse
That Fuse is F6, not F1, on my 2001 7th Gen Civic EX.
Old Nov 21, 2015
Mad Dog Tannen's Avatar
heres the fuse
You need to let it sit overnight, or hold the brakes until the light goes out. Just pulling it and putting it back in will not erase anything. I have always been told to pull the battery cable not the fuse.
Old Nov 21, 2015
False: High octane gas is not harmful to a low compression engine, it is a waste a money though. Just use what the manual says and you will be good.
Wow this thread is 6 years old.
Old Nov 21, 2015
lowlife9's Avatar
6 years old ang going strong lol dam i have learned so much since posting that thread that was one of my first.
Old Apr 3, 2016
electrodaimos's Avatar
electrodaimos is an unknown quantity at this point
So what is the correct method of resetting the ecu or which method did you end up using? i know this is an old tread but i just made the mistake of buying a 2001 civic lx as an emergency "temporary" but end up having to keep it
Old Apr 6, 2016
lowlife9's Avatar
i did gearboxs method just disconnected the battery for about 60 min. either way your car will eventually learn itself,this method just takes less time for the computer to re-learn.
Old Jul 22, 2016
Carlos-P's Avatar
Carlos-P is an unknown quantity at this point
So you are saying that all you gotta do is disconnect the whole battery and leave it off for 60 minutes and that will reset it
Old Jul 26, 2016
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Just pull the fuse, wait 10 mins put it back in, then do the re-learn. done... much easier than pulling battery cables
Old Jul 27, 2016
AlexFromCali's Avatar
AlexFromCali is an unknown quantity at this point
Should i have the key in at all
Old Jul 27, 2016
GusBuz's Avatar
Nope.. Just car off, pull fuse wait 10 mins or so till the computer capacitors are out of juice and then plug it back in. and follow the steps of the diy
Old May 14, 2017
nsrhonda89's Avatar
nsrhonda89 has a spectacular aura aboutnsrhonda89 has a spectacular aura about
Pdf guide to perform an idle relearn.
File Type: pdf
File Type: pdf
File Type: pdf
Old Dec 26, 2017
Joshhoover's Avatar
Joshhoover is an unknown quantity at this point
Do you know if you have to rest the ecu when you put a map sensor in it is still coming up p1129 code
Old Dec 27, 2017
anthonyelectric's Avatar
anthonyelectric is an unknown quantity at this point
This is a super thread. Thank you for this information
Old Dec 27, 2017
it's easy, does not require money.
Why are you waiting to try?
Old Sep 14, 2019
photiost's Avatar
photiost is an unknown quantity at this point
great thread thanks
Monkey01
Oct 16, 2014 06:11 PM
Wrench_7
Nov 18, 2010 11:39 AM
lumpy007
Jun 16, 2010 08:32 PM
ptacc9
Mar 22, 2010 12:06 PM
magic_wizard
Jul 5, 2006 01:41 PM
