p0300 stumping this gearhead....
Old Jan 2, 2015
oh05ex's Avatar
oh05ex is an unknown quantity at this point
Completely stock 05civic ex se. Been trying to track down a p0300 (&0301,0302,0303,0304). Only does it as the car heats up to op. Temp. Every every path I test (ignition,fuel & air) come back inconclusive. The only thing that temporarily eliminates this misfire is chevron techron concentrate fuel system cleaner. I dont know enough (even with the month and a half of research) about this car to test voltages completely cause it seems to change everywhere I look.
Old Jan 2, 2015
Re: p0300 stumping this gearhead....
Post the freeze frame data and the code that it's related to, please
Valve adjustment?
EGR distribution plate passages clogged?
Old Jan 2, 2015
oh05ex's Avatar
Valve adjustment?
I'll get get a freeze frame here soon. I wouldnt think valve adjustment cause when the cleaner is in it, it runs almost perfect. If I could describe it in a few words what its like, its as if the system forgets or loses when it needs to fire like its a few degrees off. Then it catches back up to where it needs to be. Until I slow down, then it forgets again when I accelerate.I havent gotten any lean codes, o2 codes, catalyst codes or anything other than 0300-0304. Btw compression is 183psi across all 4 cylinders.
Old Jan 2, 2015
How are you using that: Are you just pouring the Techron in the gas tank?
Big bottle or small?
Ever seen how badly an engine runs when the tank has waaaay too much Techron in it? LOL
SimpleUser
Apr 24, 2021 02:54 AM
Civic720
Sep 10, 2015 10:06 AM
Ronin Nishimura
Jul 28, 2015 07:24 AM
Green02civic
Jul 27, 2015 10:48 PM
EliseKStewart
Jul 15, 2015 11:11 AM
