CV Joints bad after changing balljoints/struts/tierods?
Old Dec 30, 2014
b_rayd's Avatar
b_rayd is an unknown quantity at this point
So as it says above I have a 2002 GX on which I just changed the ball joints, suspension (full unit, coil, strut, etc) and tie rod ends. Everything went fine on the installation but I did have to remove the hubs to change the ball joints. When I was pulling the axle out of the hub i noticed that the axle had play. When I say play I mean that I could pull on the axle and push it back in which seemed a little odd to me. Anyway after I put it all together the car is making noises and sort jumps (a hobble jump with acceleration) past 25 mph. I can also hear a loud clicking at times when turning. Is it possible that our of nowhere from changing those parts and removing the axles from the hub that my CV's went bad? i didn't notice any sort of clicking or anything before changing these parts. I double checked everything and it is all tight and seems okay. The CV's look okay, no torn boots or anything. Also if I change the car into drive from reverse and vice versa it will make a loud click noise after it shifts.
Any help?
Old Dec 31, 2014
Re: CV Joints bad after changing balljoints/struts/tierods?
The CV joints were not bad, the shaft is supposed to move in and out of the inboard joint.......but it sounds like you over-extended yours to the point a roller probably came off. Now it needs taken apart and corrected if it hasn't already been damaged, or just replace the damaged alxe(s).
Old Dec 31, 2014
b_rayd's Avatar
So how do I make sure if I buy new axles that I don't overextend them in the install?
Old Dec 31, 2014
Know not to do it, and avoid doing it?
Did you understand what is meant by 'overextend'?
Old Dec 31, 2014
b_rayd's Avatar
I doubt I would have asked if I knew exactly what was meant. Apparently I 'overextended' it the first time by just reinserting it into the hub and would like to avoid doing it again.
Old Dec 31, 2014
Extend would be 'make it longer'.
Overextend was 'made it TOO long'.
If you grab the 2 joints and pull them away from each other, the inboard joint comes apart, there is no retainer inside the joint cup to keep the important parts inside it.
If one of those rollers comes off the "spider", you end up with the complaints you have.
This usually happens after the lower ball joint comes apart and one yanks the knuckle outward while the stub of the outer CV joint is still stuck in the hub. The inboard joint was still stuck in the trans, the axle was extended too far, the inner joint came apart.
Helpful diagram?
Old Dec 31, 2014
You could remove the axle and carefully peel apart the bands and boot from the inner CV joint and inspect to see if I was correct. And you can then see more about how it works.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
chuffsy
May 15, 2015 12:50 PM
dragonsblood
Apr 27, 2015 12:28 PM
El_Spic
Apr 23, 2015 03:14 PM
GH04si
Apr 15, 2015 08:13 PM
