96 Civic Starting Issues
Old Dec 14, 2014
Kyjimo's Avatar
Kyjimo is an unknown quantity at this point
I've looked and please don't spam me with noob post or anything. I really need help. My buddy has a 96 Civic with a B18 and we just finished putting the new transmission in. Everything ran just fine until his roommate drove it into the backyard. First the battery ended up draining bad for sitting about 2 weeks with the door cracked open, so we replaced it. And still wont start, I thought well starter relay since it was going nuts, swapped and nothing. Now I'm either thinking the main relay by the glove box so ordered it last night. My issue I'm having is you turn the key and on acc you have power to everything like normal and can even hear the fuel pump and everything. But moment you clutch in and turn ignition to start position we lose all power to everything, every now and again you'll hear the main relay click outta control but not every time. Anyone have an idea for me before I start just rewiring everything I can think of. Thank yall alot I try not to bug people with me mechanical stupidity but this is getting frustrating.
Old Dec 14, 2014
Re: 96 Civic Starting Issues
Poor connections at the battery, battery clamps and cables, or grounding points.
Or a junk battery.
Voltage drop testing could pinpoint the source of the problem.
Old Dec 14, 2014
Kyjimo's Avatar
Or a junk battery.
I'll try checking all the grounds and the battery terminals again. And the voltage test was good with a load. I just didn't know if I'm maybe missing a fuse or maybe a wire that mighta got pulled by the clutch pedal. Thank you again ezone
Old Dec 14, 2014
If you only load tested the battery, that doesn't load the entire system.
Something (in the battery main circuits) is going 'open circuit' under the load placed by the starter.
Old Dec 16, 2014
Kyjimo's Avatar
I did the voltage load test and couldn't find anything. I was thinking maybe the clutch safety switch but it looked alright. I'm just dumbfounded and really starting to get irritated
Old Dec 16, 2014
This means the dash goes dead, the headlights are dead, no horn, no hazard lights, right?
McD
Apr 29, 2015 03:50 PM
Braun
Apr 23, 2015 09:03 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
civic_gt
Apr 19, 2015 08:15 AM
ImmortalEX
Oct 31, 2001 10:00 PM
