Options for a 2" receiver trailer hitch on a 2013 4 door sedan
Hi, my father-in-law would like to carry is motorized scooter (the kind old folks ride in malls) on the back of his 2013 (might be 2014) Civic 4 door sedan but the hitch mounted carriers need a 2" hitch receiver and all the hitches I've seen are only 1 1/4". Does anyone know where I can get a 2" hitch receiver? If I need to have it custom made, would it be easier to get a 1 1/4" hitch and then have someone modify that one?
I'm not overly concerned about the weight. The Civic is rated for 200 lbs tongue weight (I think) and the whole thing including the carrier might be about 240 lbs so it will be a bit over but just barely and he probably won't even use it that often.
Let me know if you have any suggestions. Thanks,
Mike
Mike
Re: Options for a 2" receiver trailer hitch on a 2013 4 door sedan
Custom is the only option I would know of. There are adapters to make a 1 1/4" to a 2" but that would move the carrier even further out away from the car increasing the weight point.
It would probably be easiest to buy a pre-made one and have the receiver tube changed out.
Check with these guys?
https://www.civicforums.com/forums/105-introduce-yourself/358959-greetings-hitchanything-com.html#post4659036
(I believe they are located in Florida)
Thanks for the responses. I spoke to a few welders in the area and it sounds like getting an existing 1 1/4" hitch and then modifying it to have a 2" tube isn't too difficult to do so I'll probably go that route.
DO NOT GET IT WELDED. If you need further proof - contact a company that sells hitches. Here's one you can contact: Hitchweb
Billybob1963
May 31, 2015 07:37 PM
juror
May 26, 2015 06:35 PM
