squeeky clutch pedal
Old May 11, 2002
xe2k2's Avatar
xe2k2 is an unknown quantity at this point
Today my clutch pedal started to squeek. It only makes squeeking noise when I release clutch pedal. Do i need some lubrication? or will it eventually go away? My car is a 2k1 EX with 21,xxx miles.
Old May 12, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Humm I would recommend putting something on it, it may go away but I dunno never really had a squeaky clutch pedal.
Nick
Old May 12, 2002
skitzo's Avatar
skitzo is an unknown quantity at this point
check the TSBs There is one in there for this exact issue. Go back to the dealer and make them fix it.
Old May 12, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
Some simple lubing may help get rid of it. Mine was squeaking slightly, but I lubed one of the clutch components and it went away. The sound was coming from a clutch assembly component located in front of the engine near the bottom, and covered by a rubber boot. Peel back the rubber boot and lube the parts underneath. Best way to find the sound is to have someone pump the clutch while you're looking in the engine bay... you'll be able to see and hear the moving part.
Old May 12, 2002
Macko's Avatar
Macko is an unknown quantity at this point
<< Today my clutch pedal started to squeek. It only makes squeeking noise when I release clutch pedal. Do i need some lubrication? or will it eventually go away? My car is a 2k1 EX with 21,xxx miles. >>
Before you do anything.. do this... take a look at the clutch pedal( i mean stick your head in and check) see a lil rubber boot thingy connected to the top of the clutch pedal? make sure it is not folded or like the ridges are not overlapped.... that is one problem for the squeking..
My friend always ask me where's teh squeak comming from, but i dun tell him..... i do fix it after he's not around.. i like seeing him get irritated[IMG]i/expressions/laugh2.gif[/IMG]
sometime when you clutch down to hard and pump it fast the rubber boot doesn't get nuff time to flex back into the regular shape
Old May 13, 2002
xe2k2's Avatar
what rubber boot are you talking about? I took a look but couldn't find any rubber boot where is it?
Old May 13, 2002
Ronin's Avatar
In your engine compartment, in front of your engine, waay down near the bottom, that's where part of the clutch mechanism is on our cars. Like I said before, you need someone to pump your clutch while you're looking down into that area in front of your engine. That way, you can see and hear the moving clutch parts... Otherwise, it's kinda difficult for me to show you where that part is by words alone.
edit: best thing to do at this point is to have the dealer take a look at it. It'll probably take them less than 10 minutes to lube the right part for you.
Old May 14, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Mine did the same thing for a while. Especially on rainy or humid
days. [IMG]i/expressions/face-icon-small-confused.gif[/IMG] But it hasn't done that for a long time.
Old May 15, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
Take it to honda and tell them to replace the master cylinder on the clutch. your sound would be gone. I had the same problem.
Old May 15, 2002
OverTheTop's Avatar
OverTheTop is an unknown quantity at this point
I think its just the pivet bushing. Need lube!
Old May 15, 2002
Ronin's Avatar
I don't know about replacing the whole cylinder... not sure how many dealers would do all that for you just for some squeaking. Some lube is probably all you need.
Old May 20, 2002
BlackSI's Avatar
BlackSI is an unknown quantity at this point
WD-40, takes care of all the squeaks
Old May 20, 2002
Mbow's Avatar
My clutch makes a little noise but its more of a clicking noise than a squeeking one. My 93 accord used to do the same thing and the dealer would lube the 'return spring' I think they called it. I used to get it done about once a year. They never charged me for it though. Not sure if this is the same problem, but most likely it is.
Old May 21, 2002
Jeff's Avatar
ok, im just letting you know what has happened to us at our dealership, master cylinder on the clutch wa sthe cause ofthe problem. They tried replacing the spring, didnt work, tried lub on it, didnt work either, next and final thing was the cylinder. and bingo it fixed it
Old May 21, 2002
2k1SINCE00's Avatar
2k1SINCE00 is an unknown quantity at this point
My car has been to the dealership 4x to fix the clutch squeek. One of those times they replaced the transmission too and that seemed to take care of the clutch squeek ever since. I had tranny probs too, maybe the clutch squeek is a sign of what is to come. They basically lubed the clutch pedal, said there isn't much else they could have done.
Old May 21, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
I hear the same thing too! But it's only after I get in the car after it was sitting all night...after that, the music is up too loud to hear anything!
2 Hottie
[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Jun 2, 2002
tummyboy's Avatar
tummyboy is an unknown quantity at this point
if you have an intake check the clutch line allingment I had a clicking noise and a squeek then I took it in to have it checked out the adjsuted the alingnment of it and it stopped . Not sure if this what you guys are talking about. but it worked for me
Old Jun 19, 2002
ATLCIVIC's Avatar
ATLCIVIC is an unknown quantity at this point
I HAVE A 2K1 CIVIC EX WITH THE SAME PROBLEM THEY REPLACED THE CLUTCH SLAVE AND MASTER CYLINERS THE NOISE WENT AWAY FOR 1 WEEK THE NOISE HAPPENED AGAIN THEY REPLACED THE BEARINGS IN THE CLUTCH PEDAL ASSEMBLY IT IS STILL THERE THEY LUBED THE CLUTCH ASSEMBLY NOISE HAS NOT GONE AWAY WENT TO HONDA THEY SAID UNTIL THEY HAVE A FIX FOR IT IS CONSIDERED NORMAL THAT IS B.S.
MJK ATLCIVIC
Old Jul 31, 2002
Guy01's Avatar
Guy01 is an unknown quantity at this point
hmm..i have the same problem and my clutch squeaks A LOT when i don't drive it for like a day. every morning it starts squeaking then about 10 mins later it stops. is this supposed to be covered by the warranty? i hate the service i get at my dealership
Old Jul 31, 2002
nrrhgreg's Avatar
nrrhgreg is an unknown quantity at this point
Mine was doing that, took it to the dealer, they lubed it, two days later it was squeaking again. I'll be taking it back in very soon.
Old Aug 29, 2002
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
i had the same problem, i brought it to the dealer twice, they said they lubricated it and it still squeaked. so i got really pissed and one day it squeaked really loud and i took it there and the tech told me to release the clutch pedal and he said that something was squeaking from my exhaust when i release the clutch, so i gotta bring my car back to the dealer in 2 weeks for them to look at it.
Old Aug 29, 2002
Blown's Avatar
Blown is an unknown quantity at this point
Same problem and the service guy told me he fixed it but it's still there. Quite blatently obvious that it wasn't worked on.
Old Sep 15, 2002
i brought my car in for a third time and they said they fixed it but it still sqeaks, they never even looked at the exhaust like they said they were!!! i hate them, im goin tomorrow after school to go crazy on the service manager.
Old Sep 16, 2002
incaexguy's Avatar
incaexguy is an unknown quantity at this point
My cluth pedal did this to me too for a while. I actually had forgotten about it untill reading this. It did it worse when it was wet out but it went away after a while. ??? dont know, gone now so im not too woried
Old Sep 16, 2002
Mbow's Avatar
Quote
[hr]Originally posted by: incaexguy
My cluth pedal did this to me too for a while. I actually had forgotten about it untill reading this. It did it worse when it was wet out but it went away after a while. ??? dont know, gone now so im not too woried[hr]
Yep, it has been raining the past few days and mine is making noise something awful. It's really pissing me off. I just had my oil changed and completely forgot to tell them about it.
Scout1
Oct 5, 2015 01:33 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
Klame9420
Sep 7, 2015 10:03 PM
violentpanda
Sep 7, 2015 11:49 AM
tommycanada
Sep 5, 2015 04:59 PM
