blower problem
Old Oct 16, 2014
Sheirstles's Avatar
Sheirstles is an unknown quantity at this point
blower problem
OK, the a/c on my daughter's 2003 Civic stopped working the other day. Hot day, a/c on and working fine, and then suddenly it's off. No blower. Looking carefully, neither blower or compressor are active. No heat, no a/c no nothing. Have had no troubles with this system before.
I'm reluctant to believe it is the blower switch, because the failure didn't happen when the switch was being turned.
I removed the blower motor resistor/transistor, and it checks out fine. 1500 ohms between pins 3 and 4.
I've checked fuses, though it isn't entirely clear which ones are relevant.
FWIW, the indoor filters were pretty dirty, and I cleaned them out. Maybe that led to the problem?
Where do I go from here? Help appreciated.
Old Oct 16, 2014
Re: blower problem
Blower MUST run or the HVAC computer will shut off the AC system.
Inspect/test the blower power transistor. If it's shot then check the cabin filters and amp draw of the blower.
HTH
mikemc422
Aug 9, 2018 05:41 PM
JAMorganIII
23
Jul 4, 2015 11:52 AM
jordan1794
Jun 8, 2015 08:37 PM
DouglasTheGreat
May 27, 2015 11:23 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
