2003 Civic DX Intake Manifold Gasket Differences
Old Oct 12, 2014
dinsum's Avatar
dinsum is an unknown quantity at this point
Hi,
This is my first honda car and I really do like the simplicity and mpg of this car!
I purchased it for $900 and found out a couple weeks later is had a little bit of a blown HG where some combustion was escaping through the HG to the coolant.
So i purchased complete gasket set for my engine and tore it all apart and swapped the HG, now there is no more combustion getting into the coolant which is awesome!
But there was a problem with the intake manifold gasket not being the same.
This is what the gasket I took out looked like
This is what the two gaskets that came in my gasket set looked like
ID:	87138 Click image for larger version
This is what the ports on my intake look like
This is what the ports on my head look like
Ok so from what i kind of understand here is the black/silver gasket without the holes is meant for a civic without EGR? my civic doesn't seem to have EGR and all the EGR passageways were very clean. I didn't know which gasket to use since none of the two in my kit were exactly the same as the one I took out. I went ahead and used the black/silver gasket with the extra holes and the car is working but I am hearing air hissing where the intake bolts to the head.
I guess what im wondering is, is it ok for me to use the gasket with EGR holes even though I don't have EGR? or is this maybe the reason I got the air leak? Also whats the black gasket for?? maybe I should have used it instead? its so confusing i've never seen an intake with like 3 or 4 different gaskets for the same year its crazy confusing
Any help is greatly appreciated! thanks
Old Oct 12, 2014
dinsum's Avatar
Re: 2003 Civic DX Intake Manifold Gasket Differences
Ok I grabbed a can of carb cleaner and found where the hissing is coming from, its coming from the #2 injector, my dad convinced me to remove the fuel rail to get better access to the bolts for intake removal but I knew I was goin to pay for it! I just went and grabbed a fuel injector O-ring kit, hopefully all is well after I install them
But if somebody can confirm its ok for me to be using the intake gasket with the holes that would be great!
Old Nov 11, 2014
Not sure how I missed this post, but I think it's ok to use the one with all the extra holes even without an EGR valve.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Poopies
Apr 20, 2017 11:36 PM
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
deus-ex
Apr 13, 2015 12:29 PM
