2001 Civic Headlight issue
Old Oct 10, 2014
costellol's Avatar
costellol is an unknown quantity at this point
Cool 2001 Civic Headlight issue
Hello, I just purchased a 2001 Civic EX 2 door for my son. I am going over all parts of the car getting it ready for him but I am having one repeated problem with the headlight bulbs. Here it is: I start the car then in an attempt to check the alternator I disconnect the negative on the battery and turn on the headlights and the heater blower motor full blast. After about 10-15 seconds the lights start to flicker and the low beams quit working and the heater stops blowing. I then hit the high beams and they work for a couple minutes and they stop working.
At this point the headlight bulbs have blown out. So I get new headlight bulbs and after I install them all works as intended.
I am on my second set of headlight bulbs which is getting pricey.
Shouldn't the electrical system (alternator) be able to handle all this load? I'm at a loss as to why the bulbs blow out, low beams then the high beams.
The alternator light doesn't flash but I suspect it could be weak.
Any of you pro's got an idea what could be going on?
Any help would be appreciated.....
Old Oct 10, 2014
costellol's Avatar
Re: 2001 Civic Headlight issue
I stepped away and checked the output voltage via the battery and both of my fluke meters read between 17.8 to 18.1V. I also loaded the system the best I could so I now suspect the alternator excessive output voltage is what is blowing my headlight bulbs but only when I load the system. The ELD is new.
Old Oct 10, 2014
NEVER DISCONNECT THE BATTERY OF A RUNNING CAR!!!!!!
Next things to be smoked will be any of the computers in the car. $$$$.$$
There are proper ways to test an alternator, this was not one of them. This ain't the 60's anymore.
Old Oct 12, 2014
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
It'd be free and easy to take it to your local auto parts store and have them test the battery and alternator.
mattdoc
Mar 14, 2017 12:10 PM
Rooskey
Nov 9, 2001 03:05 PM
lilbluecivic
Nov 7, 2001 06:49 PM
liljoe
Nov 4, 2001 01:27 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
