2001 Civic Headlight issue
Hello, I just purchased a 2001 Civic EX 2 door for my son. I am going over all parts of the car getting it ready for him but I am having one repeated problem with the headlight bulbs. Here it is: I start the car then in an attempt to check the alternator I disconnect the negative on the battery and turn on the headlights and the heater blower motor full blast. After about 10-15 seconds the lights start to flicker and the low beams quit working and the heater stops blowing. I then hit the high beams and they work for a couple minutes and they stop working.
At this point the headlight bulbs have blown out. So I get new headlight bulbs and after I install them all works as intended.
I am on my second set of headlight bulbs which is getting pricey.
Shouldn't the electrical system (alternator) be able to handle all this load? I'm at a loss as to why the bulbs blow out, low beams then the high beams.
The alternator light doesn't flash but I suspect it could be weak.
Any of you pro's got an idea what could be going on?
Any help would be appreciated.....
Re: 2001 Civic Headlight issue
I stepped away and checked the output voltage via the battery and both of my fluke meters read between 17.8 to 18.1V. I also loaded the system the best I could so I now suspect the alternator excessive output voltage is what is blowing my headlight bulbs but only when I load the system. The ELD is new.
NEVER DISCONNECT THE BATTERY OF A RUNNING CAR!!!!!!
Next things to be smoked will be any of the computers in the car. $$$$.$$
There are proper ways to test an alternator, this was not one of them. This ain't the 60's anymore.
mattdoc
Mar 14, 2017 12:10 PM
lilbluecivic
Nov 7, 2001 06:49 PM
