8th Gen 2006 - 2011.
2006 Clear flood mode?
Old Oct 2, 2014
styles234's Avatar
styles234 is an unknown quantity at this point
Does anyone know if the "clear flood" mode exists on the 2006 model? Where you hold the gas down and it shuts off the injectors. This is common on most other cars but I'm not sure if it exists in this one or how to do it.
Thanks
Old Oct 2, 2014
Re: 2006 Clear flood mode?
Pull the floormat out from under the gas pedal.
Mash the gas pedal to the floor and hold it there.
Crank the engine.
Does it start-- or just keep cranking continuously?
Old Oct 2, 2014
styles234's Avatar
Crank the engine.
I haven't pulled the floormat out of it, but when mashing it to the floor, it just starts up right away and revs up. I was under the impression that it shouldn't start when doing this. Or at least this is the case with every other car that I know. Does it not exist on these models?
Old Oct 2, 2014
The owners manual sure makes it sound like it has it (sedan, p163):
6. If the engine fails to start, press
the accelerator pedal all the way
down, and hold it there while
starting to clear flooding. If the
engine still does not start, return
to step 5.
I've not really ever looked to see if it actually shuts off the injectors does though.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
brash99
Sep 29, 2015 08:42 AM
Luluharp
Sep 27, 2015 11:56 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
johnsoda
Sep 6, 2015 04:00 AM
