New (used) car, bad vibrations.
Old Sep 6, 2014
Jonnythecanuck's Avatar
Jonnythecanuck is an unknown quantity at this point
Hello,
Recently I purchased a 2003 civic coupe with a manual transmission. The car has 125,000km on it and the clutch was replaced last year, apparently.
My problem is that when I start the car in first gear like I normally would, the motor shakes and vibrates badly as the clutch pedal nears the top 2/3 of the stroke.
I assumed motor mounts, and found a crack in the front mount. I replaced it and the problem remains. The other 3 mounts look fine to me.
Some facts:
- Clutch does not slip.
- Shifting is smooth.
- When I release the clutch at higher than normal RPM for me, (2k or so) vibrations are gone.
- I've driven manuals for a long time, including 2 other civics when I was looking for this car. It is not my method.
- front motor mount replaced
I am really stumped on this one. I don't know if the flywheel was resurfaced when the clutch was replaced about 1 year ago, but I assume it would have been.
Any advice would be greatly appreciated.
Old Sep 6, 2014
mikey1's Avatar
Re: New (used) car, bad vibrations.
well then why did you not notice this issue when you took the car for a test ride before you decided to purchase it? (assuming you did drive it before purchase, like any normal person would)
Old Sep 6, 2014
I needed a car immediately. Condition was great, price was good, and these civics with low KM go fast here. I was the first to see the car after it was posted. On level ground, it's not bad. The vibrations are much worse on hills or with a lot of weight in the car, and when the car is cold. I did notice the issue during the test drive, but it didn't concern me much at the time. I could also not communicate well with the owner (purchased in Quebec, my French is basic)
Why I purchased the car is my decision. The circumstances when I purchased the car were complicated, and I am not going to get into the details on this forum.
Thank you for any assistance with troubleshooting the issue.
Old Sep 6, 2014
Sounds like you described clutch chatter.
I assume the engine and trans mounts are all good now?
I'd probably either suggest a clutch job using OE parts, or live with the annoyance until it's time to do a clutch job.
I always had the best luck not touching the flywheel during a clutch job.
Honda does not recommend resurfacing the flywheel. If there was any question about its condition, I would have recommended replacement.
Old Sep 7, 2014
Thanks for the reply, ezone.
I put the car on jack stands and crawled under to get a good look at the rear mount. The rubber looked fine, but then I saw this.
One of the bolts on the rear mount was not fully threaded in. I was very happy to see this as I was sure this was the cause. I tightened the bolt, checked the other to ensure they were tight, and took the car for a test drive.
The vibration seems less, I think... but definitely still there. damn.
dragonsblood
Apr 27, 2015 12:28 PM
Fastfebur
Apr 26, 2015 11:57 PM
tattedlariat
Apr 20, 2015 09:26 PM
GH04si
Apr 15, 2015 08:13 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
