04 Civic Coupe Hood Release Knob Broken off
Old Sep 3, 2014
dbailey's Avatar
dbailey is an unknown quantity at this point
04 Civic Coupe Hood Release **** Broken off
I understand that the hood release **** breaking off is a fairly common problem. Mine broke off. Any ideas on how to fix it without having to disassemble half of the car replacing the entire cable? Thanks guys.
Old Sep 3, 2014
mikey1's Avatar
Re: 04 Civic Coupe Hood Release **** Broken off
are you talking about the level inside the car?
Old Sep 3, 2014
dbailey's Avatar
Yes that one
Old Sep 3, 2014
mikey1's Avatar
Originally Posted by dbailey
Yes that one
i have never heard of the actual lever breaking, are you sure its not the cable that broke?
Old Sep 3, 2014
The plastic handle breaks off rather often......maybe because the cable needed replaced?
Fix for the lazy:
Old Sep 3, 2014
dbailey's Avatar
Its for sure the **** end of the cable that broke off. You can grip the stub IF you can get a hold of it and open the hood. The vise grip idea is a good one. Also saw a YouTube where a guy took like a 3/16 drill stop sleeve with a set screw in the side of it and put it on the end of the stub and walla. Ordered a set of drill stops on eBay and will see if that does the trick.
Old Jan 28, 2015
CivicHell2's Avatar
CivicHell2 is an unknown quantity at this point
Hoping this hleps:
Old Jan 28, 2015
dbailey's Avatar
Thanks for the video! When I looked to see what it would take to replace the cable, it appeared as I recall to be allot more involved with the bumper cover than on the year model range in the video. Maybe a big change after 2000? I just wound up buying a drill bit stop collar type thingy and putting it on the end where the handle broke off and so far so good.
Poopies
Apr 20, 2017 11:36 PM
miatabro
Jul 17, 2015 12:12 PM
shaejb15
Apr 26, 2015 07:44 PM
15EXCoupe
Apr 19, 2015 09:26 PM
CapYoda
Nov 11, 2001 05:17 PM
