rear power window driver side problem
Old Aug 15, 2014
truck7575's Avatar
truck7575 is an unknown quantity at this point
My rear window has stopped rolling down... When I apply direct 12 volt power to the regulator it goes up and down fine and the switch shows appropriate continuity in both directions and the fuse under the das aren't blown.. Ideas??
Old Aug 16, 2014
Re: rear power window driver side problem
Broken wire in the rear door jamb where the harness flexes every time you open the door?
Old Aug 17, 2014
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Most likely a broken wire. Just isolate the break with a test light or multimeter and solder in a new portion of wire.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
ej8
Apr 13, 2015 06:36 PM
mwwhonda
Nov 7, 2001 07:24 PM
EXWisdom
Nov 5, 2001 10:24 PM
