Will '02 Si Struts work on a '01 EX?
Old Aug 8, 2014
zman4011's Avatar
zman4011 is an unknown quantity at this point
Found some on craigslist (Model: S5T (RR) R-AO, NISSIN SHOWA) for a 02 Si.....need some badly for my 01 EX. Will they fit?
http://sfbay.craigslist.org/scz/pts/4604424242.html
Old Aug 9, 2014
Re: Will '02 Si Struts work on a '01 EX?
US Si model will require using 16mm crash bolts on the front. You will need drill the knuckles holes to 16 (2001 have 14mm bolts)
Old Aug 9, 2014
lowlife9's Avatar
i think if hes putting 16mm struts on a 01 he will need reducer washers not drilling. if he was using 01 struts on a 02+ there would require drilling ??? K-sport sells reducer washers the last time i checked.or maybe im just confused.
Old Aug 10, 2014
Lowlife,
yer right, for some reason i mixed up - yes, reducer washers should work.
Old Aug 12, 2014
bravo79's Avatar
bravo79 is an unknown quantity at this point
So the fronts fits with reducer washers ? This means 03 05 civics and RSX and EP3 ?
what about the rear struts?
Read this thread
http://honda-tech.com/showthread.php?t=1715937
ORskier
May 3, 2015 12:54 PM
GH04si
Apr 15, 2015 08:13 PM
thesushiboy
Apr 12, 2015 02:54 AM
