Car Shakes at High Speeds
Hello all,
I'm having issues with my 07 Civic where I start to get vibration from the gas pedal when accelerating (and slight steering wheel shake as well) and I also am having significant shaking coming from the steering wheel when braking at around 65-80mph. It's not very noticeable at speeds below 55mph, if at all. I recently had my passenger front axle replaced at the dealership due to popping noises from doing sharp turns and parallel parking. I performed all 4 wheel balance afterward at a separate garage in the hopes it would fix it. The balance did provide some help, but the issues are still there. Car has 110k miles and I bought cert. used at 58k. Any ideas on what could be the issue(s)?
Re: Car Shakes at High Speeds
I have exactly to same issue and i am trying very hard to figure it out. If you read the forums you will know that there can be a lot of reasons behind this issue and diagnosing it will take time. I am going to get my tie rod changed this weekend in hopes that it might solve the problem.
Get all the front end components checked.
dragonsblood
Apr 27, 2015 12:28 PM
GH04si
Apr 15, 2015 08:13 PM
dooner24
Apr 14, 2015 07:51 PM
