NGK or DENSO?
Hi there,
For a civic 2007 Ex manual transmission, Honda Dealer by my house told me to use Denso Plugs cause NGk Plugs is for Automatic transmision is that right or can I put Ngk Izfr6k11s in my Manual Civic.
Thanks guys.
Thanks guys.
Re: NGK or DENSO?
Reality: Either.
The engine is no different and will not care one way or the other.
The USA parts catalog lists both brands and does not differentiate between transmissions, body styles, trim levels (except Si), or country of build.
If you are really worried about it, pull a plug out and see who made it. Get the same plugs.
EDIT: Oh, I looked up a sedan at first.
Now I see a coupe shows different plugs for each trans choice. F* that, the engines are exactly the same as a sedan.
My catalog shows
IZFR6K-11S NGK (a/t for coupe)
SKJ20DR-M11S DENSO (m/t for coupe)
But sedan can use either....???? Someone got a contract I bet!
HTH
My catalog shows
HTH
Re: NGK or DENSO?
Reality: Either.
My catalog shows
HTH
My catalog shows
HTH
Re: NGK or DENSO?
It sound like your mechanic was playing a game of "I don't want to climb the ladder right now to grab the NGks." The fact is no plugs will give enough performance boost to damage your transmission or drivetrain. I have used NGK Iridiums in all of my bikes as well as my Civic. They definitely help smooth things out on the high end(10K+) and add MAYBE 3 horses. It's negligible. Anyways, I would recommend them for your car. I believe that they were put on at 50k miles in mine, and at 145k right now they show no symptoms of wearing out. Definitely worth the 10 bucks apiece.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
JetsterDajet
52
May 8, 2016 12:11 AM
Bruce2
Sep 27, 2015 08:45 PM
winanthony94
Sep 25, 2015 09:05 AM
