3500 rev limit
Old Jun 3, 2014
Zaridar's Avatar
Zaridar is an unknown quantity at this point
3500 rev limit
Anyone know why my car seems like it has a 3500 rev limit under load while driving? Thought it was a trans issue but now I'm thinking electrical. It is fine if u don't give it a lot of throttle. But if u do it rev limits in all gears...
01 civic ex automatic
Old Jun 3, 2014
mikey1's Avatar
Re: 3500 rev limit
possible timing issue, your timing belt might have jumped a tooth or two, could also be your crank or cam sensor, is your engine light on?
Old Jun 3, 2014
Re: 3500 rev limit
Code P1259?
How low is the engine oil?
Old Jun 3, 2014
Zaridar's Avatar
Yes v tec code is on but I disconnected the solenoid and same issue... Oil was 1/2 qt low but I topped it off
Old Jun 3, 2014
Zaridar's Avatar
Codes..
Old Jun 3, 2014
Re: 3500 rev limit
Well duh, it's gonna set codes like that. You have to solve the problem, not disconnect stuff.
P1753: TCC sol valve circuit. This is an electrical problem. Unplugged?
P1298, replace the ELD. There's a bulletin on this.
P1457, EVAP leak, canister system. Need diag.
P0141, rear O2 heater circuit. Probably bad sensor, needs checked.
Old Jun 4, 2014
Zaridar's Avatar
I was told by a very experienced import mech to disconnect the v tec solenoid to see if the studdering goes away... If it's unplugged, he told me, v tech should not try to kick on/off. Since then I think I realized it's not the actual v tech making the surging but a rev limit... Do these cars have this as safety if v tec fails??? I think u helped me realize I'm thinking too far into it and helped me answer my own question...
Tcc was from when I tested all trans solenoids.. Forgot to reconnect...
Not worried about other codes right now... I'll take off and test v tec solenoid and check the screen to see if it's clogged...
Ahhhhhh I just rembered when I changed valve cover gasket the engine was very sludgy... I used some motor medic motor flush... Probably dislodged junk and plugged it maybe?
Old Jun 4, 2014
Re: 3500 rev limit
Yes.
Very possible. Clogged screen in the VTEC gasket could cause a drop in oil pressure and set code.
Old Jun 5, 2014
Zaridar's Avatar
Ok thanks I'll check it once I get my 7 out of the garage...
Old Jun 12, 2014
Zaridar's Avatar
Problem resolved. One of the v tec solenoid connectors was not connected Plus the screen was pretty full of junk from the oil.. Also I had added the incorrect oil weight (20w50) To top off when it was low... Motor flush, oil change w 5w20, cleaned screen, connected both electrical connectors , and D/C battery.. Runs great!
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
carid
Sep 28, 2015 10:13 AM
99BoostedSi
Sep 7, 2015 04:49 PM
