1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Buying a 1995 civic
Old May 6, 2014
sylas's Avatar
sylas is an unknown quantity at this point
Buying a 1995 civic
hi, I'm buying a junky rusty dented 95 civic 5 speed tommorow for $275, it runs and drives/shifts good, but the body is in pretty bad shape. i looked underneath (at night) and it doesnt seem to be rusty down there, there is minor bumper damage looks like it was a little bumper bender type accident, My plan is to replace the entire body, but i was wondering what i should look for to know if the clips or however they are connected, arnt broken or out of place. this is a 4 door non hatch by the way.
EDIT: also, where would a good place to buy stock body parts from?
Old May 7, 2014
SeAmUs_MaCk's Avatar
SOHC Enthusiast
SeAmUs_MaCk will become famous soon enough
Re: Buying a 1995 civic
If you don't care how the body looks for now then definitely buy it. But open the hood first (In the DAY TIME) and look for any serious oil leaks. See what color the oil is....If its any kind of milky color, that means that the head gasket is without a doubt blown. Listen for any kind of real weird noises....let it warm up to normal operating temp, and make sure you have a good idol. Then i would put the car on a flat road....put it in 1st....and slowwwwwly let the clutch out with NO GAS....if it doesn't stall then your clutch is still in halfway decent shape....for the small amount of money your buying this for I really couldn't find a reason not to buy it unless any of the problems mentioned above are occurring. IF its over 200k try and get an idea when the timing belt/water pump were changed if ever. If theres a CEL (Check engine light) then find out what the code is and make sure its nothing too serious....{Its an OBD-1 ECU, so all you have to do is jump your green 2 pin connector under passenger kick panel} I'm not going to explain how to do that, you can search for the code list and exact "how to" Make sure your exhaust isn't completely rusted through and its going to just give way at any moment. A little bit of rust under the car is expected, depicting how the body seems, but make sure your exhaust manifolds aren't cracked and haven't been spot welded. Post some pics before you buy it, and we can probably give you a better idea. But check the mentioned things...and if everything seems good, then I would buy it in a heart beat....just to have around for parts at that price
Oh and find out if it's a D16z6 or the NON-VTEC {D15**} I think
Annnd i didn't even answer your question...haha.....
Umm Craig's list for stock parts...Ebay....Or the market place....people sell and trade things on here....just gotta search and ask
Last edited by SeAmUs_MaCk; May 7, 2014 at 02:53 PM. Reason: Forgot to answer question...went on ranting
Old May 7, 2014
sylas's Avatar
I've driven it already, didnt try the slow clutch release though, its been parked in the same spot for a while and i didnt notice any fluid leakage, and it is a Vtech. I'll be buying it today regardless, its a piece of **** but it will be cheap to drive, cheap to repair.
its also at 200k+ miles, ill have to check for the timing belt/water pump things.
seemed to idle good, didnt notice any problems
EDIT: also, i dont recall the check engine light being on but i do know the ABS light was on, breaks worked good though.
this will be my first civic btw :P
Old May 7, 2014
GolNat's Avatar
Prelude Owner
Check local junk yards for parts. Join a forum dedicated to 5th gen civics for more part options, also check here.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
beneditti
Jan 15, 2016 12:31 PM
bsmiley
Apr 27, 2015 01:27 PM
LionSpratt
Apr 26, 2015 01:02 PM
inarschenk
South
Apr 18, 2015 04:29 PM
