Auto tranny fluid change
Old Mar 9, 2014
0396's Avatar
0396 is an unknown quantity at this point
I figured I ask the experts here on trannies.
I have a 2012 HF and just changed the trannie oil.....and made a mistake on how to check. I originally had it running and now just realized that I should have warmed the drive train and TURN off the car to check. The fluid is in my guesstimate 1/2 qt OVER. I've read that it's best to NOT over fill. So I plan on draining a little after car cools off.
My other question is, has anyone ever used Swepco Trannie oil in their Hondas?
....that's what I just put in. To my knowledge it's made for industrial applications / heavy duty stuff like buses and is all synthetic. I put 7 miles on it and it shifts smoother.
Any comments? Thanks
Old Mar 9, 2014
Re: Auto tranny fluid change
What was wrong with using the correct specified Honda DW-1 automatic transmission fluid, available at any Honda or Acura dealer?
Old Mar 9, 2014
0396's Avatar
I've used the Honda fluids the past two changes. As for Swepco, I use it in my Audi S/4 and in my Porsche....figured I try it in the 2012 HF.
Old Mar 10, 2014
mikey1's Avatar
your not currently servicing an audi or porsche,
its very important to use honda oem tranny fluid and nothing else,
many people have had tranny issues when going with other fluids,
and if you still have a warranty it will most likely be void now (on the tranny)
Old Mar 10, 2014
0396's Avatar
What's so special about the Honda fluid? This Swepco I've used is industrial grade.
Old Mar 10, 2014
Hondas DW-1 is the ONLY approved fluid.
That doesn't make it the correct fluid.
Old Mar 10, 2014
0396's Avatar
Ok...today I went and purchased 3qts of Honda ATF and will change it out. Lesson learned.
Thanks
Old Mar 11, 2014
mikey1's Avatar
Thanks
that won't work,
when you drain the tranny your only getting out about 1/3 of the fluid,
you will still have alot of the wrong fluid in there,
you would need to drain and fill it probably 5 times in a row to get all the fluid out
civic__duty
24
Jun 11, 2015 12:29 PM
MajTom
Jun 2, 2015 11:48 AM
bsmiley
Apr 27, 2015 01:27 PM
02Si
Dec 14, 2001 10:26 AM
CiViCPrAnInG2k1
Dec 6, 2001 12:14 PM
