Passenger lock and window not working (same door)
Old Jan 21, 2014
8Radiant's Avatar
8Radiant is an unknown quantity at this point
On the driver's side rear door both the window and the lock stopped working. At first the problem was intermittent and then they stopped working completely.
Could these 2 things be related or are they separate problems?
Old Jan 21, 2014
CraigW's Avatar
Re: Passenger lock and window not working (same door)
Broken wires in door jamb harness ??
Old Jan 21, 2014
8Radiant's Avatar
Hhm, when it comes to electrical problems I'm kind of lost. I'm thinking about taking it to a dealer but I know I'm gonna get bent over.
Old Jan 21, 2014
CraigW's Avatar
Try a local mechanic, post up your year and maybe we can give you the wire color info to help them trace. ezone has mentioned several time how cheap the complete harness section is compared to attempted repair of broken wires (if this is the case)
Old Jan 21, 2014
8Radiant's Avatar
It's a 2002 LX.
Old Jan 21, 2014
Drivers side REAR door...
peel the black rubber boot away from the section of wiring in the jamb, you should find at least one of the wires broken.
The left rear door harness is 32754-S5A-000,
I show (USD) $22.20 MSRP..
Same # at Toronto shows about $31
Dirt cheap IMO.
Old Jan 21, 2014
8Radiant's Avatar
I will take a look in the door jamb and see what I find.
Old Jan 21, 2014
8Radiant's Avatar
I found a broken wire inside the door jamb so it looks like I'll be replacing the wiring harness. How tough of a job is it for a beginner? If there's a good guide somewhere I should be ok doing it I think.
Replacing this should fix both the lock AND the window right?
Thanks a lot for the advice.
Old Jan 21, 2014
Get the door panel off and everything unplugged, pry all the holders off the door (squeeze the tabs to release if you can), keep watch where everything is routed (mark everything with a sharpie or something if you need to), slap the new in exactly the same way.
YW.
You'll find out after it's installed. LOL
One broken wire was for the power window, that seems consistent here.
Were there any other wires broken??
The lock may or may not be related to the wiring.....the actuators do get weak and quit now and then.
Old Jan 21, 2014
8Radiant's Avatar
I only found 1 wire that was broken, then again I could only peel back the rubber tubing a small ways. Guess I'll order that harness from torontohondaparts and find out.
Old Jan 21, 2014
Better have them double check the part number, the catalogs might be different between US and Canada. (And I don't want to be responsible for looking up wrong parts!)
You could stick a 12v light bulb in the connector for the lock actuator and see if it lights up as you work the power locks. If it lights up, the wires for it are assumed ok (at that position, because broken wires in the jamb can reconnect as the door swings) and the actuator is blamed.
Old Jan 22, 2014
CraigW's Avatar
It's a 2002 LX.
Here is the info.
https://www.civicforums.com/forums/a...7&d=1350598426
https://www.civicforums.com/forums/a...8&d=1247931161
Old Jan 29, 2014
8Radiant's Avatar
After replacing the wiring harness both the power window and lock now work.
Thanks a lot guys.
Old Jan 29, 2014
Yay
You can send all the loot you saved by DIY, to my paypal account!
Old Jan 30, 2014
CraigW's Avatar
Thanks for posting results !!
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Laurenhunter7
May 10, 2015 01:09 PM
ORskier
May 3, 2015 12:54 PM
