05 EX SE antifreeze/coolant leak - solution provided in link
Old Dec 18, 2013
Alann's Avatar
Alann is an unknown quantity at this point
I did a high level search to look for duplicate posts but didn't see anything that followed my issue. If you know of one please post the link.
My issue is that I replaced the thermostat and water pump because my heat would not work when the vehicle was idle. Now that these have been changed out, I am now seeing that i have a slow coolant leak. A tech friend told me it would most likely be the gasket(o-ring) around the water pump, but I found that the overflow reservoir lid was no put on correctly. I corrected this which helped but this morning my heat was barely working while the vehicle was moving (low coolant?). I went to check the level of coolant, which when i started to remove the radiator cap, the coolant started shooting out of the overflow at the cap. I am also only seeing coolant spray remnants near the overflow area and cannot really see anything on the belts that are near the water pump.
Any ideas?
Old Dec 18, 2013
Re: 05 EX SE antifreeze/coolant leak
2nd thread today, same answer
https://www.civicforums.com/forums/3...reference.html
Old Dec 18, 2013
Alann's Avatar
Re: 05 EX SE antifreeze/coolant leak - solution
Thank you for this information. However, your link was posting double in the address bar. Here is a working link https://www.civicforums.com/forums/3...reference.html. I will mark this as fixed.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
davidpaustin
May 7, 2015 05:08 PM
davidpaustin
Apr 30, 2015 11:20 PM
cooldan1
Apr 23, 2015 10:49 AM
