Quick Battery Question
Old Nov 22, 2013
zman4011's Avatar
zman4011 is an unknown quantity at this point
My 2001 Honda Civic EX is on its last legs.....and I need a new battery (sluggish, churning start). I cleaned up the contacts and topped off the cells but no improvement. Anyways......I don't feel like shelling out $100+ for a battery for this car. Someone is selling a used group size 51R battery on craigslist for $20...... that should work shouldn't it?
Old Nov 22, 2013
GolNat's Avatar
Prelude Owner
Re: Quick Battery Question
No, R means reversed terminals.
And if you flip it the hood prop hits it.
Old Nov 22, 2013
Basically, the Interstate site says that civic should have a group 51 battery.
The 51R has the posts reversed, so you either have to drop the battery in backwards, or make the cables stretch.
Will the battery cables connect to their correct posts?
Will the hood close without hitting the positive cable end?
Will the hood prop rod hit the positive post?
<---(I've seen this at some point)
Is that battery even any good? How can YOU tell?
http://www.interstatedealers.com/IBCatalog/common/
Home > Automotive > Honda > Civic, Civic Wagovan > 2005-01 > L4/1.7L > Standard Batteries
Old Jan 30, 2015
Idaho Hick's Avatar
Idaho Hick is an unknown quantity at this point
This answers the question I was going to post. I guess the search function DOES work
I just bought a 2001 LX Sedan for my daughter and the prop rod rides on top of the positive battery terminal. Does not look safe to me. I guess then that the only solution is to purchase the correct battery.
Does COSTCO or Sam's Club carry the reversed terminal battery, or do I have to buy one from Honda?
Mike
Old Jan 30, 2015
CraigW's Avatar
^^^Check your application for correct fit.
Certainly available at about any auto parts store.
Old Jan 30, 2015
GolNat's Avatar
Prelude Owner
Getting the correct battery is the only solution I see.
Like Craig said any parts store should carry the correct battery.
Old Jan 30, 2015
Any battery retailer......that hires employees with working brain cells.
(WALMART, I'm looking at you!)
Not all are smart enough to understand that a prop rod laying on the positive post could be an issue, and not all are smart enough to figure out an acceptable solution.
Old Jan 30, 2015
CraigW's Avatar
After they rip the red plastic cover off to make more room.
Old Jan 31, 2015
Idaho Hick's Avatar
YES! Whoever installed the battery took the protective cover off of the positive end (and apparently threw it out). I have to buy another after I have fixed this.
I stopped at COSTCO and they did not have the correct battery. They carry the Interstate 51R and the terminals are in the wrong position on that battery. The fitment guide says 51 (without the "R"), but they do not carry that battery.
I will look at Wal-Mart tomorrow and get back to you.
Mike
thana
Jun 15, 2015 11:58 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
manicEL
Dec 10, 2001 06:33 PM
viper775
Dec 9, 2001 10:52 PM
MooCoW
Nov 9, 2001 05:22 PM
