P0122 Throttle body sensor
Old Sep 20, 2013
whittam's Avatar
whittam is an unknown quantity at this point
2002 Civic 1.7l 4 door keeps showing a Check engine light, 3 times in last 2 years. Code behind the light is P0122 throttle body sensor. I buy a can of carb/throttle body cleaner and empty the can into the throttle body. Light typically goes our or I just reset it. I'm good to go for 4-6 months then the light comes on again. Can anyone explain what is going on electrically or with this sensor. Is the carb cleaner really doing anything or am I just getting lucky?
Has anyone changed this sensor which is riveted into the throttle body.
Thanks Terry
Old Sep 20, 2013
Re: P0122 Throttle body sensor
The code actually is defined as "Throttle Position Sensor Circuit Low Voltage".
The definition above explains what the computer thinks is wrong.
I think it's the latter of the two.
Honda makes you purchase the complete throttle body.
I have seen aftermarket sources that say they sell the sensor by itself...
Those are not rivets, they are really screws that had breakaway heads. A sort of tamper resistant bolt.
Properly adjusting the sensor after replacement is critical to proper operation of the engine.
Old Mar 28, 2014
RMYLY's Avatar
RMYLY is an unknown quantity at this point
Had the same code...and car did not want to shift properly..it would rev to 3000 rpm b4 shifting heavily into gear..did not trust it on hiway,so never had it over 40klm/hr.
Anyway after much research and planning to either change TPS or the entire throttle-body..decided to do some maintence which i needed anyway..
Changed air-filter,plugs and specific to the throttle concern...used the body-cleaner and totally cleaned body,especially inside and seafoamed it afterward.
Noticed a ring of carbon/gunk around the body where the plate sits at idle and spent lots of time cleaning it well.
Result is that the code has stayed off for over 500klm Of driving so far...previously it was returning within 10-20klm of city driving.( after pulling #6 fuse and resetting)
Sure theyre are those that will find it a coincidence but im sure that this repaired the p0122 code problem.
If u have neglected maintenance ,air-filter,plugs etc. i would definetly do this prior to changing TPS/THROTTLE-BODY.
Good-luck.
BootyDo
Jun 21, 2016 03:45 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Jul 12, 2015 11:54 AM
Ccoop87
Jul 9, 2015 03:26 PM
7thgensurvivor
Jul 5, 2015 12:17 PM
