2006 DX - rough manual shift
Old Sep 5, 2013
knewknow's Avatar
knewknow is an unknown quantity at this point
I've read quite a few posts about rough manual shifting, but nothing is quite like what I'm experiencing.
Upon pushing down on the gas after any gear change (1-2, 2-3 etc..) I'll experience a jerk. This happens at low or high rpm, and it almost seems that it's not responding quickly enough to the gas after letting go during shift. Also while driving if I let go of the gas while in gear and quickly press down, the car jerks a bit. This may be normal and not related to the shift problem though...
Any help/insight would be much appreciated. Thanks.
Old Sep 5, 2013
Re: 2006 DX - rough manual shift
Have you driven another identical Civic to compare?
I'd suggest you do this first.
Is your check engine light on?
Old Sep 5, 2013
knewknow's Avatar
No I haven't, but I have always wanted to to see if this is "normal". I can't see this being the way dbw is supposed to work. If so, it's pretty terrible. Now I need to get my hands on a similar Honda... Not sure how I'm going to find one.
Oh, and no, no engine light on.
Old Sep 5, 2013
Fly-by-wire does feel a little different from a cable operated throttle, it took me just a little getting used to the first few times I drove them back when Honda first started using them.
Some other manufacturers have been using them for well over a decade already. They definitely do not all react the same, some manufacturers' products have a definite lag in response time. Others react dang quick.
Foot timing is everything LOL.
I might drive 50 different cars in a week. I can adapt pretty fast.
Old Sep 5, 2013
knewknow's Avatar
Yea this is the reason that I'm concerned. I've been driving manual for 20 years (3 different cars), and have been putting up with this "problem" for almost 3 years now and no clutch/gas timing is consistent enough for a smooth shift. It's very frustrating.
Edit: I bought this 2006 approx. 3 years ago, and this weird issue has always existed.
Old Sep 5, 2013
I'd think that finding an identical manual trans Civic 06-11 would make a good comparison.
Or get someone intimately familiar with the cars to give it a quick test drive to see if something obviously isn't right.
Go to a dealer for an oil change? Ask for a senior (a well experienced) tech to give it a quick drive, describe your issue so he knows what you are after. To someone like me, it should be quickly apparent if the car drives like most others or not.
The reason I say that is at our shop, a quick 1-2 mile test drive just to confirm a complaint could be free...but to go any further in the diagnosis will cost you.
You decide the next step.
HTH
Burnout
Jul 15, 2022 10:24 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
cruisers10
May 12, 2015 10:46 PM
01CivicEXs
Transmission
Jan 21, 2002 09:55 PM
CiViCPrAnInG2k1
Jan 2, 2002 06:57 AM
