97 Civic Front speakers not working after headunit install.
Old Aug 5, 2013
khar's Avatar
khar is an unknown quantity at this point
I recently installed a new head unit and my front speakers will not work. The Passenger tweeter does work and at times both speakers will work. The speakers work with the old radio. I pulled them out and tested them directly to head unit and they worked so they aren't blown. When I was installing the head unit , the blue power antennae trigger connector came loose from the head unit, so I didn't not connect the blue cable leading from the vehicle to the head unit. Could this be the cause of the speakers not working, I thought the blue wire was only used to power amps?
Old Aug 5, 2013
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: 97 Civic Front speakers not working after headunit install.
The blue wire is a remote turn on wire. It is used for amps and in some cars power antennas or antenna amps.
If you speakers work sometimes and not others it is a short somewhere. Either in your connection from the head unit to the harness, somewhere in the speaker wiring, the speaker connection or in the head unit itself.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
