97 Civic Front speakers not working after headunit install. - Honda Civic Forum
Old 08-05-2013
khar is an unknown quantity at this point
I recently installed a new head unit and my front speakers will not work. The Passenger tweeter does work and at times both speakers will work. The speakers work with the old radio. I pulled them out and tested them directly to head unit and they worked so they aren't blown. When I was installing the head unit , the blue power antennae trigger connector came loose from the head unit, so I didn't not connect the blue cable leading from the vehicle to the head unit. Could this be the cause of the speakers not working, I thought the blue wire was only used to power amps?
khar is offline
Old 08-06-2013
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: 97 Civic Front speakers not working after headunit install.
The blue wire is a remote turn on wire. It is used for amps and in some cars power antennas or antenna amps.
If you speakers work sometimes and not others it is a short somewhere. Either in your connection from the head unit to the harness, somewhere in the speaker wiring, the speaker connection or in the head unit itself.
TiggerDX is offline
CarStuff
Safety/Security Items
10-11-2018 01:29 PM
Dorval Andre
7th Generation Civic
25
07-23-2017 04:08 PM
bsmiley
04-27-2015 02:27 PM
GH04si
04-15-2015 09:13 PM
JeffSpeed21
11-03-2001 11:32 AM
Quick Reply: 97 Civic Front speakers not working after headunit install.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
