Check Engine Light coming on and Off
Old Apr 14, 2013
spaniks's Avatar
spaniks is an unknown quantity at this point
I just bought a used 2002 civic about a month ago and the check engine light came on after I filled up for gas the first time. I waited a week or two to see if it would just go off by itself but it did not so I reset it by pulling the #6 fuse. After I did this the light was off, and stayed off for my trip to school (10km), but came back on on my way home. I reset it again but the same thing happened, does anyone have any idea what this might be? Could it just be something with the gas cap or something, or should I just bring it into a mechanic to get a diagnostic run on it? Thanks for any help.
Old Apr 14, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: Check Engine Light coming on and Off
You need to get the code read. Nobody can really help you until you do that.
Old Apr 14, 2013
spaniks's Avatar
alright thanks ill bring it to a mechanic and do that then
Old Apr 15, 2013
mikey1's Avatar
replace your gas cap
Old Apr 15, 2013
Matt_75's Avatar
^I'd agree with that except I'd like to see a code that's related to that e.g. P0457 or something and not that it's a coincidence it came on and it's something else.
Old Apr 15, 2013
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Got to autozone or one of those other stores to get the code read. They often do it for free.
Old Apr 15, 2013
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Since it keeps coming back let us know what the says ang get back to us!!
Old Apr 16, 2013
mikey1's Avatar
yeah i guess, however, gas caps are so cheap, personally i would just grab one and see if it fixes it, seems like a strange coincidence it happened right after he put gas in
Old Apr 16, 2013
ProAc_Fan's Avatar
ProAc_Fan is an unknown quantity at this point
Could be a bunch of things. I agree you need to have the codes pulled first. Wasting any money throwing parts at it s silly. Could be gas cap, could be purge valve on the evap canister, could be something entirely unrelated to the fuel system.
Mike
Old Apr 17, 2013
mikey1's Avatar
Mike
gas cap is the most likely cause,
i wouldnt call replacing a gas cap "throwing parts at it",
even if it doesn't fix the problem, its cheap and should probably be replaced by now anyway
Old Apr 17, 2013
04 Honda Civic's Avatar
Personally I would wait as well.
From what I read, the car actually goes through a "check" many times after refueling and can throw a CEL if the "check" sees a problem
I had this happen with an O2 sensor CEL right after filling up, literally pulling out of the gas station.
Personally, I wouldnt change anything until the code is pulled.
Old Apr 18, 2013
daught's Avatar
daught is an unknown quantity at this point
Some cars give you a EVAP code if you overfill the tank. Dunno if the civics are sensitive but usually it's not a good idea to go fill the tank after the pump clicks off the first time.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
thana
Jun 15, 2020 07:05 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
