Shock/Lowering Springs combo?
Old Mar 12, 2013
rAfOOL's Avatar
rAfOOL is an unknown quantity at this point
After doing some research I figured that Koni Yellows are the best way to go for shocks. However, I don't know what lowering springs to choose. Right now I'm leaning towards Skunk2, Einbach, or H&R. But others are referring Tein lowering springs. I want to drop my car 1.5"-2". I also want a stiffer ride, but I don't want coilovers.
Old Mar 12, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: Shock/Lowering Springs combo?
Ground Control springs.
Old Mar 12, 2013
GolNat's Avatar
Prelude Owner
Koni's are really nice but they might be a little over kill if your only going down an inch or so and are not going to have a high spring rate. I have Eibach Sportlines and Tokico's. they offer a great balance between comfort and handleing. Koni's are a pain to instal also, Tokico's are direct bolt on.
Old Mar 12, 2013
Kennykid2002's Avatar
Kenny the Ricer
Eibachs will be good if you want a stiffer ride.
Teins tend to give a softer/smoother ride, which I like better.
Junk2's will break your spine.
Old Mar 12, 2013
rAfOOL's Avatar
What do you mean by it may be overkill? How low should the car drop if using Koni's? I've read people using them and dropping 1.5"
Old Mar 12, 2013
H&R seem to have good reviews for civics
neuspeed as well
i use the eibachs and work great for me.
Old Mar 13, 2013
rAfOOL's Avatar
If I get Neuspeed springs will it "look" level between the rear wheel and wheel well?? I was reading that Eibachs and other springs make the front look higher than the rear because of the left/right wheel turn in the front.
Old Mar 13, 2013
GolNat's Avatar
Prelude Owner
Because of the extra work required to instal Koni's, you could use a Tokico and be fine (since you are not slamming it and using high spring rates). If you don't mind doing the extra instal required with the Koni's then they would be a great addition to any lowering spring.
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
