Shock/Lowering Springs combo?
Rep Power: 0 Shock/Lowering Springs combo?
After doing some research I figured that Koni Yellows are the best way to go for shocks. However, I don't know what lowering springs to choose. Right now I'm leaning towards Skunk2, Einbach, or H&R. But others are referring Tein lowering springs. I want to drop my car 1.5"-2". I also want a stiffer ride, but I don't want coilovers.
Prelude Owner
Re: Shock/Lowering Springs combo?
Koni's are really nice but they might be a little over kill if your only going down an inch or so and are not going to have a high spring rate. I have Eibach Sportlines and Tokico's. they offer a great balance between comfort and handleing. Koni's are a pain to instal also, Tokico's are direct bolt on.
Rep Power: 0 Re: Shock/Lowering Springs combo?
What do you mean by it may be overkill? How low should the car drop if using Koni's? I've read people using them and dropping 1.5"
Received 1,440 Likes
Rep Power: 338 Re: Shock/Lowering Springs combo?
H&R seem to have good reviews for civics
neuspeed as well
i use the eibachs and work great for me.
neuspeed as well
If I get Neuspeed springs will it "look" level between the rear wheel and wheel well?? I was reading that Eibachs and other springs make the front look higher than the rear because of the left/right wheel turn in the front.
Prelude Owner
Because of the extra work required to instal Koni's, you could use a Tokico and be fine (since you are not slamming it and using high spring rates). If you don't mind doing the extra instal required with the Koni's then they would be a great addition to any lowering spring.
beanhead
09-24-2015 12:04 PM
TheRiddicles
09-21-2015 01:28 AM
