Adjusted my valves, no what?
ok today at work i replaced and did the following,
- new timing belt
- new plugs
- Valve Cover Gasket/ Plug Tube Gaskets
- Coolant Flush
- Adjusted the Valves to spec
- New o2 sensor
now heres my issue, its ticking pretty loud. When i replace the head gasket i got the head machined and pressure tested, and everything checked out. so im pretty stumped on whats next to look at. Im thinking maybe a bent valve? becuz its also burning oil. I need this car to be able to pass emissions, the MIL light is not on.
- new timing belt
- new plugs
- Coolant Flush
- New o2 sensor
Re: Adjusted my valves, no what?
well i know there is an exhaust leak at the gasket where header meets the exhaust pipe. its got an aftermarket exhaust and header on it and the person that put it on didnt put a gasket or its brittle and cracked. but i didnt think an exhaust leak would make the valves tick loud? maybe i should look into a new motor if valves are bent? idk anything about internals on motors. any insight is greatly appreciated.
Thanks
Thanks
I bet you need to readjust the valves properly. Have a pro with plenty of experience in this particular area show you how. Technique and feel just can't be described easily in writing.
How on Earth did you do the head gasket if you don't know anything about internal engine stuff?
(Motors are electric.)
What do you see that makes you say this?
Why was the head pulled?
thaler4cuse
Sep 7, 2015 08:25 PM
Klame9420
Aug 13, 2015 06:00 PM
fred57
Aug 1, 2015 08:45 AM
