Where to have head gasket replaced
Old Jan 14, 2013
Orcus332's Avatar
Orcus332 is an unknown quantity at this point
Hi everyone,
I suspect my car has a blown head gasket (which i can go into more detail if you'd like). I have a 2005 civic ex with 83k miles on it. I hear the timing belt and water pump should be replaced around 100k. I'm wondering if I should have my mechanic do both jobs at once to save money, or if you think there is really no cost savings vs doing them separate, and i can hold out longer before having the water pump and timing belt replaced?
Also, Any thoughts on if i should have the stealership do this, or call around to the local shops. I'm in Columbus, OH so lots of options.
Thanks!
Old Jan 14, 2013
Re: Where to have head gasket replaced
Yes, do it now with the head gasket job.
You are at 7 years anyway, it is time for the timing belt job according to your manual.
IF I was the one doing the head gasket job, the extra labor to add a timing belt and water pump (according to the labor guide we use at work) would be a shade over an hour labor fee, plus the parts prices.
And don't call the place I work a stealership.
Old Jan 14, 2013
Orcus332's Avatar
Thanks for the response. I won't go into details with why I'm not a fan of the dealership, so sorry if i offended you.
Anyone have an unbiased opinion if a local shop can/should do this vs the dealer? I know honda's often require "honda parts" so I'm not sure if it would be a problem having a non-dealership do the repairs. Any preference for one vs the other?
Old Jan 14, 2013
A broken car is extremely stressful for the car owner. But it is an everyday thing for me.
I am aware that many shops out there don't have stellar reputations and don't employ a full staff of top-gun talent. Dealer and independent are both guilty of this.
I know that not everyone has great experiences with car repair, in general. The place I work is guilty of this at times, I'm sure.
I've been in the business for over 25 years now, I know a lot about how and why it is the way it is.
This applies to both dealers AND independents.
Plenty of sharp techs work in dealers, and plenty of sharp techs work in independent shops.
Plenty of hacks work in both places too.
I know all of us that wear a shop uniform may look the same to some people, but we all have differing abilities and talents. You probably don't want a knuckle dragging, mouth breathing hack to slam it together.
Choose someone competent that you are comfortable with and that you can trust.
Anyway.......
You can request factory parts be used if you wish.
Any respectable shop will honor that request.
Any experienced tech that is able and competent can do the job, it's not rocket science and it isn't any sort of exclusive "dealer only" work.
Attention to detail is certainly good.
Certs are good.
Reputation is good.
How they handle a mistake tells an awful lot about the business.
The wrong person can turn that engine into a paperweight.
Dealer or independent, the shop does not matter.
The person matters.
Choose wisely.
HTH?
Old Jan 14, 2013
Orcus332's Avatar
Is the head gasket, timing belt, and water pump something that needs to be OEM or can this be done with non-honda brand parts?
The reason I ask is that i've heard non-honda radiator caps and thermostats are notorious for not working properly. I'm wondering if the other parts I've listed are also notorious for not working if non OEM.
Thanks again!
Old Jan 14, 2013
There is a thread here somewhere that the general consensus is OEM is the preferred head gasket.
IMO, since all Honda engines will trash themselves badly ($$$$.$$) if the timing belt lets go, it behooves you to use the best parts you can get when it comes to timing components.....that includes the water pump since it is driven by the timing belt, and the correct coolant that protects and lubricates that pump.
Cheap parts are cheap for a reason.
Factory parts can be priceless.
Many factory parts really aren't much more expensive than aftermarket IMO. Especially if you know how to buy them.
Old Jan 14, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
I was searching the net and came across this....link below.
http://www.procivic.com/pages-produc...363/index.html
Do you have any opinion good or bad if this would prevent an HG failure if all other parts/systems were maintained properly?
For $90 plus shipping I would hope it would impervious to any driving habit.
Old Jan 15, 2013
IDK. The 7th gen is already MLS type.
Your call.
If I had to live with one of these, I'd be most interested in adapting TTY head bolts to it.
Old Jan 15, 2013
Matt_75's Avatar
Yeah. As you've said before TTY bolts would probably be the solution for the OEM HG as far as failures go.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mrohitredd
18
May 14, 2015 07:35 PM
HondaHomer
May 14, 2015 12:24 PM
hokiedad4
May 3, 2015 10:06 PM
green01civic
Apr 29, 2015 01:36 PM
