My Front Desk Meters are going off and on - malfunctioning meters
Old Jan 14, 2013
myzahoor's Avatar
myzahoor is an unknown quantity at this point
Hi there,
Please need your help here. I got Honda Civic 2004 and am having problem with my meters. all the meters like speedo meter, gasoline, temperature and exelerator meters are going off and on. some times they remain off for number of days, and all of a sudden start functioning. What could be the problem. i had the car electrician to check the fuses they are all ok.
what need to be checked.
thanks.
Old Jan 14, 2013
Re: My Front Desk Meters are going off and on - malfunctioning meters
Are any of the warning lights also affected?
How about illumination lighting?
(Looking for more clues here.)
When they don't work, try banging your fist on top of the dash over the gauges. (Like smacking the side of an old TV set when it doesn't work right.)
See if that has any effect.
I would probably start with making sure the connectors for the gauge cluster are fully plugged in.
Then, with the engine running so the gauges should be operational, wiggle each connector while watching the gauges. See if that has any effect.
If both wiring connectors are plugged in and seated properly, it kinda sounds like the problem will be in the circuit board.
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
Readypro
May 2, 2015 12:23 AM
tylerginevan
Apr 27, 2015 12:29 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
